ray_young
Sep 30, 2016Follower
setup advice - time to upgrade?
Hi There, Recently started working in a small graphic design studio and have inherited responsibilty for the server! It currently consists of a ReadyNAS NV+ (4 disks, 52% of 1380 GB used), gig ...
aalexandrebeta
Feb 28, 2017Master
funglennyou are right, If you are running a business an on site backup is mandatory and offsite too. If your home and office are distant you can do it like that!! And each device under strict warranty!!! Out of warranty equipment should only be used as a plan C or D end temporarily!
Mar 01, 2017Guru - Experienced User
This thread had been dormant for 5 months.
In my opinion, responding to long-dormant threads isn't that helpful. The OP usually isn't paying attention any more. And if you are running into the same or similar problems, it's usually better to start a fresh one (linking to the original if you think it is relevant).
