coelacant
Dec 13, 2012Aspirant
shares missing after drive failure
Hi there, this is my first post. I have searched the forum archive, however I am still not sure what to do. ReadyNAS Pro 6 [X-RAID2], 4 x 2TB Seagate drives I frequently get this (on every driv...
Feb 27, 2013Guru - Experienced User
coelacant wrote: ...
Another thing I asked several times was, what do you do if you want to use something like Seagate's seatools? Do you remove the drive while the NAS is on? Do you format the drive before you put it back into the NAS? Whilst the NAS is on?
My take is:...
- Remove suspect drive whilst NAS is on
- Check drive
- Format drive (netgear supported didn't explicitly say, but kind of hinted that it would be a good idea)
- Put drive back into NAS whilst NAS is on
If the disk is ok, your process is needlessly stressing the array - if there is different drive that is failing you will lose your data.
That is because your method will wipe the suspect drive when you reinsert it, forcing a loss of redundancy until the array resyncs. (even if you skip the format step).
Seatools won't change the contents of the disk. So start with:
- Remove suspect drive whilst NAS is OFF
- Check drive (leaving the NAS OFF)
- Power the NAS back on
