arul999
Jul 04, 2020Aspirant
Shares missing in Readynas admin page
Hi, need some help here...
I logged into the Readynas admin page and noticed that my shares were missing the “shares” tab. Instead I only see “ Home folders” folder which has nothing in there. The data capacity show the correct amount . Not sure why the shares are not appearing.
Hope the data is not lost..
Many thanks in advance.
- SandsharkSensei
Do you normally access the files in another way? If so, do you still have access? Are you comfortable with the Linux CLI via SSH?
There is a script available that might fix your situation, but we need to make sure of the current condition of the files and shares to be sure it's the right fix for you.
- arul999AspirantI normally access the folder in windows explorer. They are not showing up in there as well. Can see the home folder only.
Yeah, I’m ok with ssh.- StephenBGuru - Experienced User
Start by enabling it in system->settings->services. Log in as root, using the nas admin password.
First see if the shares and files are present in your data volume (default is /data ).
