dbott67
May 30, 2008Guide
Spec Sheets and Replacement Parts
I figured that it might be a good idea to create a thread where people might be able to obtain information about Infrant-branded ReadyNAS products that may no longer be produced or for products that are out of warranty.
Owners of Netgear-branded products should contact Netgear support.
Anyhow, here are a few links to existing threads that offer solutions, spec sheets, part numbers or third-party replacement items for the older Infrant-branded line-up. Feel free to add your own findings to the list.
-Dave
Spec Sheets:
ReadyNAS 600: http://www.infrant.com/download/ReadyNAS600
ReadyNAS X6: http://www.infrant.com/download/ReadyNAS_X6
ReadyNAS NV: http://www.infrant.com/download/ReadyNAS_NV
ReadyNAS NV+: http://www.infrant.com/download/ReadyNAS_NV+
ReadyNAS 1100: http://www.infrant.com/download/ReadyNAS1100
Cross-reference Table of Duo, NV+, 1100 and Pro:
From this thread:
viewtopic.php?f=24&t=18617#p100422
http://www.bott.ca/files/ReadyNAS_comparison.xls
Determining Revision Number for ReadyNAS 600:
faq.php#What_ReadyNAS_600_revision_do_I_have%3F
Replacing PSU with 3rd Party Power Supply:
If you are having difficulty locating a replacement PSU from Netgear, you can elect to purchase a PSU from a third party, such as Enhance. The NV/NV+ PSU require modification from the standard ATX wiring. A number of users have posted there instructions in thread #1 (below). TrophyGeek & kspades have also posted photos.
1. viewtopic.php?f=11&t=13492&st=0&sk=t&sd=a
2. viewtopic.php?f=7&t=18618
As for the 600 & X6 ReadyNAS, the device uses a standard connector ATX PSU (although the form-factor is different). The only difference between the A & B models is that the 600 Rev. A requires a 20-pin ATX with 4 SATA connections, similar to something like this:
viewtopic.php?f=7&t=18618&p=100893#p100893
The original PSU for the X6/600a/600b was made by Enhance Power (http://www.enhanceusa.com) and was model # ENP-2222F. The A revision of the 600 had 4 SATA connectors, but it carried the same model # as the X6/600b (see pics below by chirpa).
ReadyNAS PSU Pin-out Information:
http://www.infrant.com/download/ReadyNAS_PSU_pinout.pdf
Official NV/NV+ Power Replacement Instructions:
faq.php#How_do_I_replace_the_stock_power_supply_on_the_ReadyNas_NV%2FNV%2B%3F
http://www.readynas.com/download/docume ... %20PSU.pdf
Parts List:
Here are some other part numbers listed from http://www.archive.org's cache of shop-infrant.com:
MAJOR DISCLAIMER: This is cached version of the site as it existed in August of 2007. Parts, prices, availabilty may have changed. This is for entertainment purposes only. :)
-Dave
-Dave
Spec Sheets:
From this thread:
Parts List:
Parts and accessories
Lockable disk tray for Infrant ReadyNAS NV+
Part# RNV2-DTR1
RNV2-DTR1
Price:$25.00
Chassis fan for Infrant ReadyNAS NV+, 12VDC, 92mm
Part# RNV2-FAN1
RNV2-FAN1
Price:$20.00
AC power supply for Infrant ReadyNAS NV+, 100-240 VAC, 50/60 Hz
Part# RNV2-PSU2
RNV2-PSU2
Price:$120.00
AC Power Supply Unit for ReadyNAS 1100, 100-240VAC, 50/60 Hz
Part# RN1100-PSU1
RN1100-PSU1
Price:$140.00
Hotswapple Disk Tray for ReadyNAS 1100, Single
Part# RN1100-TRAY1
RN1100-TRAY1
Price:$25.00
Chassis Cooling Fan for ReadyNAS 1100
Part# RN1100-FAN1
RN1100-FAN1
Price:$15.00
Optional 26" Rack Mount Sliding Rail for ReadyNAS 1100.
Part# RN1100-SR26
RN1100-SR26
Price:$60.00
1GB SODIMM for NV and NV+
Part# 1GBSODIMM
Price:$140.00
Cross flow fan for Version A ReadyNAS 600/X6
Part# RN06-FAN1
Price:$20.00
120mm Fan Retrofit Kit for ReadyNAS 600/X6 Version B.
Part# RN06-B120KIT
ReadyNAS 600/X6 Version B 120mm Fan Retrofit Kit
Price:$40.00
Infrant ReadyNAS 600/X6 (Version A) Power Supply Unit
Part# RN06-PSU1
Price:$60.00
Infrant ReadyNAS 600/X6 (Version B) Power Supply Unit
Part# RN06-PSU2
Price:$60.00
Pre-configured 750GB HDD with Disk Tray for NV/NV+
Part# B750640NS
750GB Pre-configured Seagate ES HDD for ReadyNAS NV/NV+
Price:$470.00
Pre-configured 500GB HDD with Disk Tray for NV/NV+
Part# B500630NS
500GB Pre-configured Seagate ES HDD for ReadyNAS NV/NV+
Price:$240.00
Pre-configured 250GB HDD with Disk Tray for NV/NV+
Part# B250620NS
250GB Pre-configured Seagate ES HDD for ReadyNAS NV/NV+
Price:$130.00
Pre-configured 400GB HDD with Disk Tray for NV/NV+
Part# B400620NS
400GB Pre-configured Seagate ES HDD for ReadyNAS NV/NV+
Price:$195.00
Chassis Cooling Fan for ReadyNAS 1000S (single)
Part# RN1000S-FAN1
RN1000S-FAN1
Price:$10.00
Chassis Cooling Fan for ReadyNAS 1000S (dual fan w/single connector)
Part# RN1000S-FAN2
RN1000S-FAN2
Price:$10.00
ReadyNAS NV/NV+ Disk Installation Screws.
Part# RNV-SCREW
Price:$5.00
-Dave
- andyvAspirantI have an X6 and need to replace Fan 3 again - we did it almost exactly a year ago. Previously, I just ordered it from the Infrant Store but since that is no more, I'm not sure where I can purchase it from. Does anyone on the board have any suggestions as to how to approach this?
Thanks,
Andy
Name Code Qty Each Options
Cross flow fan for RN06-FAN1 1 20.00
(Shipped) - dbott67Guide
andyv wrote: I have an X6 and need to replace Fan 3 again - we did it almost exactly a year ago. Previously, I just ordered it from the Infrant Store but since that is no more, I'm not sure where I can purchase it from. Does anyone on the board have any suggestions as to how to approach this?
Thanks,
Andy
(Shipped)
I think this may do it for you:
from this thread: viewtopic.php?f=7&t=18618&start=0&st=0&sk=t&sd=aChocomonsters wrote: I have replaced the fan twice so far in my ReadyNas x-6 rev A. Once fan has failed and it was replaced under warranty. Second time it was out of warranty and it was making rattling noise.
I found an identical fan manufactured for Silverstone by a third party in Taiwan. I've purchased it through NewEgg. I am not sure NetGear will sanction this fan, but if your NAS is out of warranty it is an option.
You can search for SILVERSTONE RL-FX121 Case Fan ( http://www.newegg.com/Product/Product.a ... 6835220002 ).
Blessed by a Jedi:chirpa wrote: Yes, the FX-121 from Silverstone is a suitable replacement. - chirpaLuminaryGreat collection Dave!
I'll add one thing...
The Jedi have drive tray SCREWS available for $5.99 (includes shipping) upon request (USA only). PM me for info. - andyvAspirantThanks all - I appreciate the fast help.
- chirpaLuminaryReadyNAS 600 RevA PSU:
ReadyNAS 600 RevB PSU:
ReadyNAS 600 Cross-Flow Fan:
- chirpaLuminaryReadyNAS NV/NV+ PSU:
ReadyNAS 1000s PSU:
ReadyNAS 1100 PSU:
- chirpaLuminaryDisk Tray Screw specs: viewtopic.php?p=105952#p105952
- onsetitAspirantI need to replace the fan in a ReadyNAS 1000s. The replacement part is RN1000-S. It is discontinued. Where can I find a 3rd party fan??
Thanks! - Can someone confirm that this is the same size and specs?
My concern is that it doesnt appear to have the same sata conectors!
ENP-2222F = 220W TFX 12V Power Supply; 140x85x62 mm
http://enhance-electronics.industrialpa ... -2222f.htm
Part Number:ENP-2222F
Model Number:ENP-2222F
Make:ENHANCE ELECTRONICS
Lead Time:Available
Qty In Stock:Available
================ http://www.itus.se/pdf/tfx12v/enp2220f.pdf ======OLD Version Maybe===
================ http://www.itus.se/pdf/tfx12v/enp2222f.pdf =======================
TFX 12V ENP2222F 220W
TFX 12V Compliant Passive PFC
Remote on/off Manual select switch
Protection High Output Current for +5Vsb
Short Circuit
Over Voltage Protection
UL / cUL, CB, TUV Safety approved
FCC / CE EMC Approved
High efficiency Dimension ( W x L x H ) : 85 x 140 x 62 mm
Optional Fan Speed Thermal Control
Voltage RegulationMinimum Maximum Peak
+3.3V +/-5% 0.3A 17A --
+5V +/-5% 0.3A 13A --
+12V +/-5% 1.0A 16A 17A
-12V +/-10% 0A 0.3A --
+5Vsb +/-5% 0A 2.0A 2.5A
* 3.3V & 5V combine load 80W
Input Voltage 100 -127/200 - 240VAC Manual select switch
Frequency 47 ~ 63 Hz
Input Current
5A @ 115VAC
3A @ 230VAC
Hold up time 16ms@ full load
High efficiency 70% at Full Load
+5V Output ≦ 7.5V Max
+3.3V Output ≦ 4.3V Max
+12V Output ≦ 16.2V Max
Short-Circuit Protection On each channel
Environmental Specification
Operating / Storage Temp 0 ~ 40oC / -20 ~ 70oC
Relative Humidity 5 ~ 95%
Operating / Storage Altitude 10,000 / 50,000 FT
MTBF 100,000 HRS
Safety Approvals UL/CUL, CB, TUV,
Nemko
EMC Regulations FCC, CE
Apply for All Intel Processors upto P4
All AMD Processors upto Athlon
Last Update : 7/2/2003
USA OFFICE
13100 ALONDRA BLVD., UNIT 106,
CERRITOS, CA 90703
E-MAIL : sales@enhanceusa.com
TEL : +1 562 677 1268 FAX : +1 562 677 1269 - GladysAspirantHi Chirpa,
Is there a way I can order a replacement X6 Rev A PSU?
Thanks,
