GavMcB
Jan 06, 2015Aspirant
Strange Ultra 4+ Issue
I am having my first real problem with a ReadyNAS device. It started when i was replacing the final 2 3TB Seagate drives to 4TB ones (the Hitachi ones from the HCL for the Ultra 4+). I had replaced di...
RX
Jan 06, 2015Luminary
Do you have a spare disk other than the 4 drives inside your NAS? I suggest that you factory reset your NAS using a spare disk then re-insert your existing 4 drives accordingly to their original bays and check if same problem will occur.
What is the current firmware of your NAS?
