mhellstrand's avatar
Feb 05, 2014
Swap disks between readynas units.
Hi!
Is it possible to use disks from an existing RND2000 Duo V2 system (data on the disks) in a Netgear ReadyNAS 102 2-Bay NAS?
To my knowledge they have the same CPU architecture? (Marvell ARM CPU vs. Marvell ARMADA 370 1.2 GHz)
Is there any where I can get hold of a "table" over the different Readynas units and their CPU architecture, so when I want to buy a new one I can select one that will accept my "old" disks without wiping them clean from data?
many thanks
//Martin
  • No.
    The problem is not the processor, it's the operating system and the filesystem on the disks.
    The following are 5 lists, each list of units would allow disks to be moved between them.
    102/104/2120
    312/314/316/516/3220/4220/716
    Pro/NVX/Ultra/2100/3100/3200/4200
    NV+(v2)/Duo(v2)
    NV+(v1)/Duo(v1)/NV/1100/1000/X6/600
    You will need to setup the new nas and transfer the data across a network, possibly using backup jobs.
  • StephenB's avatar
    Although I haven't tried it, I've seen posts here that say you can migrate between RN1xx and RN3xx/Rn5xx. Apparently the new NAS does an OS reinstall, and the file system is preserved. Not sure what happens to apps.
    Apart from that possibility, these lists look correct to me.
ProSupport for Business
