pfrom
Mar 27, 2015Aspirant
system enhancement 2nd hd
i installed a new rn 104 as one disk System with disk seagate st4000dx001-1ce168
ther are no Problems it works all perfect.
i use the x raid 2 volume
now i want to enhance with a second disk same type
but this disk is formated as nfs
can i use it witout Problems by inserting it by running System ?
the second disk is fore dundancy
- NhellieVirtuosoPlease check the link below, it will give you the needed information to use a previously formatted disk to your NAS:
http://kb.netgear.com/app/answers/detai ... -6-desktop - vandermerweMasterIf you just stick the disk in with the nas on it should be formatted by the nas, regardless of how it is currently formatted.
It used to be that way, but i believe OS6 added a format step because too many people assumed their NTFS-formatted disk would be preserved (and lost data).vandermerwe wrote: If you just stick the disk in with the nas on it should be formatted by the nas, regardless of how it is currently formatted.
In any event, you can just insert the disk as vandermerwe says. Then check the volume tab of the web admin GUI (selecting the new disk). If you need to format, the format button on the right should be enabled.
