aalexandrebeta's avatar
Feb 09, 2017
Theoric HDD limit acording to devices
I'd like to know what are the limits acording to protfolio devices?
  • StephenB's avatar
    Feb 09, 2017
    aalexandrebeta wrote:
    What HDD max capacity is it possible to install acording to the type of devices?
    RN series, legacy, etc......
    The limits I know about:
    4.1.x (duo v1, nv+ v1, etc):  2 TB disk limit
    4.2.x: (ultra, pro, etc):  Some rackmount models have a 2 TB disk limit in some slots.  Otherwise, no known limit on disk size, but there are limits on volume expansion.  A volume can't expand over 16 TiB, and it can't expand more than 8 TiB from its starting point.  Volumes over 16 TiB can still be created on 64 bit plaforms, but 32 bit platforms (NVX) have a hard volume limit of 16 TiB.
    5.x (duo v2, nv+ v1):  No known disk size limits, but the same volume expansion limits of 4.2.x.
    6.x (RN10x, etc):  No known disk size limits, and no known volume size limits on any platform running firmware 6.4.0 or newer.  ARM models have a limit on the maximum iSCSI LUN size (8 TB).
  • StephenB's avatar
    I don't understand the question - can you rephrase it?
    • aalexandrebeta's avatar
      aalexandrebeta
      Master
      What HDD max capacity is it possible to instal acording to the type of devices?
      • StephenB's avatar
ProSupport for Business
