pkraiker
Sep 17, 2012Aspirant
Trying to use ST3000DM001 3TB drive in USB dock
I have 4 of these drives in my NV+ and want to use them for backups and/or hot swap for the raid array so I picked up 2 more along with a BlacX eSata dock to use for USB backups. This HDD/dock config replaces an older NexStar I've been using with Sata2 drives. Before buying these drives I checked that they were on the supported list. I beleive that's for internal use though, not USB connectivity.
I can format the drives on both my iMac and MacBook using the dock and see the full capacity. When I connect the dock/drive to my NV+ it sees it but says it has a whopping 196.9MB of storage (100% is free though!). I've tried the FAT variations available as well as the journaled Mac FS options. I don't see a way to format EXT anything (running OS/X 10.8.1)
My old backup relied on 1TB drives, with the new config I can't back up on those.
What am I missing? Is there a way to format the drives from SSH? Some parm I'm missing? Not supported (yet)?
And yes I installed the latest firmware before attempting all this. I also looked through the forum and found similar threads but no matches.
PK
PK
- pkraikerAspirantParted comparing two drives, the first (correctly identified as an ST3000DM001) is part of the 4 drive raid while the latter (labeled as the same but recognized as an Initio) is the in the USB dock. The second partition was created on OS/X but is not recognized by the NAS.
Model: Seagate ST3000DM001-9YN1 (scsi)
Disk /dev/sdd: 3001GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Number Start End Size File system Name Flags
1 32.8kB 4295MB 4295MB raid
2 4295MB 4832MB 537MB raid
3 4832MB 3001GB 2996GB raid
Model: Initio INIC-1610P (scsi)
Disk /dev/sde: 3001GB
1 20.5kB 210MB 210MB fat32 EFI System Partition boot
2 211MB 3001GB 3000GB USB3TB005 - mdgm-ntgrNETGEAR Employee RetiredYou probably need to delete the partitions on the USB disk, create a new one and format it.
- pkraikerAspirant
mdgm wrote: You probably need to delete the partitions on the USB disk, create a new one and format it.
Bingo, thanks mdgm.
I used parted to remove the partitions and then I was able to get mkfs.ext3 to work correctly
Partition Table: loop
Number Start End Size File system Flags
1 0.00B 3001GB 3001GB ext3 - stevenDAspirantI have the same problem but are on RAIDiator 4.1.10 [1.00a043] (ReadyNAS NV+),
and neither sgdisk or apt-get is working.
Can someone please post the commands I need to execute to delete the partition and create a new one? I'm know a bit of linux/unix, but only the basics like handling files and stuff.
My USB drive is mounted on /dev/sda1
