Steve_46
Jul 17, 2011Aspirant
Ultra 2 Temp 1 sensor
I just purchased an Ultra 2 diskless NAS and have installed two Seagate ST2000DL003 2TB drives.
I am concerned about the temperature readings I'm getting on Temp 1. I have the Ultra 2 set to spin down the
drives after 15 minutes of inactivity and these are the temp readings I see this morning after
turning the system back on.
Temp 1 = 168 degrees F
Temp 2 = 82.4 degrees F
Fan speed = 598 rpm
Firmware 4.2.17
I have completed the initial setup steps but have not started actively using the Ultra 2 yet until I determine if this is a problem that requires replacement.
I currently have the Ultra 2 completely powered off. Since there are several other posts reporting the same issue in Ultra 2's using a variety of HDD's would
it be safe to assume there may be a problem with the Temp 1 sensors? Any update is appreciated. Thank you.
Fan speed = 598 rpm
Firmware 4.2.17
- de_niroGuidePlease see this link:
viewtopic.php?f=51&t=52310
You need upgrade this beta version(4.2.17-T2) to avoid Temp sensors issue for ultra 2 and Pro 2 units. - chirpaLuminaryHe is already using 4.2.17. Using an older beta firmware will not help.
Steve, can you submit your system logs (link in my sig)? - Steve_46AspirantSubmitted system logs as requested. Thank you.
- gjsAspirantI have to hook on on this topic, having heat issues with my Ultra 2 (2x2TB).
On consecutive nights it emailed warnings temperature about 80C threshold exceeded.
This morning the unit was not accessible and the Fan was running on full speed until unit was powered down. - DarynAspirantI'm curious what the outcome was for the original poster. My ultra 2+ runs just as hot. I was initially concerned when I purchased the unit because compiles would cause it to send overheat messages. Then after I got it setup, it was one of those out of sight, out of mind issues.
It's currently idling at 761rpm with temp 1: 168F, temp 2: 95F. It's in an open air setting with ambient 78F. When the temp creeps closer to 170F, the fan eventually kicks up to ~1200 or ~1500 until the temps are down to 159F/91F. Then the fan drops back to ~760 rpms and the temp goes back up.
Tonight my phone starts blipping with overheating emails while I was recompiling some apps.
Aug 8 00:20:40 ReadyNAS-Ultra2 RAIDiator: Temperature sensor 1 reports out of normal range [expected range: 0-80C/32-176F, current: 82.0C/179.6F].
Aug 8 00:21:06 ReadyNAS-Ultra2 RAIDiator: Temperature sensor 1 reports out of normal range [expected range: 0-80C/32-176F, current: 82.0C/179.6F].
Aug 8 00:21:33 ReadyNAS-Ultra2 RAIDiator: Temperature sensor 1 reports out of normal range [expected range: 0-80C/32-176F, current: 83.0C/181.4F].
If relevant, because I see it mentioned in another thread, I also have "Unable to read TjMax from CPU" in my logs. - pl804GuideI have the same problem, where on not too hot days, the temp sensor indicates very high temps. Ultra 2. Are these units defective?
