HjalleX's avatar
HjalleX
Follower
Jul 24, 2011
Ultra 4 power supply?
Unfortunately my Ultra 4 got hit by lightning. I was behind a Belkin SurgeMaster, together with some other equipment. However that did not save me. A modem is now broke ant the power adapter of an external HD is also broke. But the worst part is that my NAS is awfully quite. I called Netgear support and got the message that there is now service available and no exchangeable parts either. But I dissembled the NAS and had a look myself. The power supply is from FSP Group Inc and the model number is FSP120-40LE. Is it really impossible to order a new one?
My other alternative will be to order a new NAS without any discs and put my old ones in. Then hopefully they still work and my data is still there. :-}
  • Interesting that the NV+ and NVX both have more powerful PSUs installed. The NV+ uses a 200W PSU, and you can order a spare from the Netgear Store. The NVX uses a 220W PSU but from the specs and the label on your PSU indicate that the Ultra 4 uses a 120W unit. It looks physically identical in layout to the PSU found in the NV+ and NVX. Interestingly also the PSU found in both the NVX and NV+ do not have the label such as found on your PSU, although I am sure all are made by third parties.
    I do note that Amazon has a fanless 120W PSU made by FSP (FSP120-50GNF), but looking at the pin out on my spare NV+ PSU and the image on Amazon and to no surprise there is no match. Both are 20pin ATX main power connectors. It has been said on these forums many times in the past that a standard ATX 20 pin PSU will not match the pin connection. Some have taken standard ATX PSUs and carefully removed enough of the connectors and rearranged them so that they then matched the ReadyNAS standard.
    Since you have it disassembled, if you could take photos of both sides of the 20 pin connector and post those it would tell us if the pin out on the Ultra 4 and NV+ are the same. (I know the pin out on the NV+ and NVX match).
    Be prepared though, for the reason there is no service available, is that a lightning strike many times does more damage than is readily apparent. You can remove the drives, and connect them to a SATA port on the MB and perform the vendor tests. This will at least tell you if the drives are still viable. Make sure that you note the bay from which each drive was removed.
    Makes a good case for a UPS which also provides surge protection.
  • I have the same type of PSU installed on my NAS. It has a 4x4 cm small fan (which make a very loud noise). So why is selling NetGear NV+ without a PSU fan (but with more Watt) and put a fan into a 120 Watt unit?!?!
    So in theory I could order a "Netgear RND4PSU1-10000S" and swap my PSU right? Since the Netgear RND4PSU1-10000S should have 200 Watt any my only 120 Watt?
    Edit
    This here should be the correct spare parts numbers if I´m correct.
    RND4PSU1-10000S
    - Fanless
    - 200 Watt
    RNR4PSU1-10000S
    - small (noisy) fan
    - 120 Watt
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Without the PSU Fan some dead spots wouldn't be covered and the hardware would likely fail quicker. Replacing the PSU with a PSU not designed for your system would void the warranty.
ProSupport for Business
