LeKing
Jul 03, 2011Aspirant
ultra 6 plus limited to 10 Tio on line
Expansion fails continuously with 6 hdd caviar green 3 To ; I think it is due to limitation to 16 Tio from the BIOs, but if parity disks would be managed separately, the partition should grow up beyon...
kurfuer
got the answer, online expansion is possible by 8TB maximum for lifetime of the ext4 filesystem, maybe you hit this border.
official answer is to backup/factory reset/restore, but I was able to do a offline expansion.
viewtopic.php?f=51&t=51475&p=294588#p294588
