LeKing
Jul 03, 2011Aspirant
ultra 6 plus limited to 10 Tio on line
Expansion fails continuously with 6 hdd caviar green 3 To ; I think it is due to limitation to 16 Tio from the BIOs, but if parity disks would be managed separately, the partition should grow up beyon...
LeKing
Jul 05, 2011Aspirant
since dead status on channel 5 after swapping, I did a scan with hddregenerator, 99.9% scan without errors, then stuck, extracting disk resulted with a BSOD...
