LeKing
Jul 03, 2011Aspirant
ultra 6 plus limited to 10 Tio on line
Expansion fails continuously with 6 hdd caviar green 3 To ; I think it is due to limitation to 16 Tio from the BIOs, but if parity disks would be managed separately, the partition should grow up beyon...
PapaBear1
Jul 06, 2011Apprentice
First - which WD Caviar Green 3TB did you install in your Ultra 6? Of the three models listed on Newegg (all 3TB Green) only one is on the HCL.
Second - you are supposed to run the vendors test, not a third party test. The vendors test has specific tests for their drives. Did you download Data Lifeguard from WD and try it?
Third - A BSOD on your PC cannot be caused by the NAS. I am assuming that it was either the drive or the testing software.
