Gopher21's avatar
Gopher21
Unable to find manual for ReadyNas model RNR-4C
Does anyone know where I can find the manual for a ReadyNas model RNR-4C
  • StephenB's avatar
    ReadyNAS part numbers and labels can be confusing, but I think you have an RR2304.  If the NAS is operational, RAIDar (and the admin web UI) should give you the model information.  Here's an image of the model I think you have:
    If I am correct, then you can find doumentation here: https://www.netgear.com/support/product/RR2304.aspx#docs
    • Gopher21's avatar
      Gopher21
      Thanks Stephan B you are correct the model No. 2304 is shown in the web user interface.
ProSupport for Business
