bibo_net24
Jun 19, 2017Aspirant
UPS USB EATON AND READYNAS DUO ULTRA
Lately, I have a UPS Eaton Ellipse Pro 1200, plugged in via USB with a ReadyNas Duo Ultra, which makes UPS servers for two more ReadyNas Duo and a ReadyNas 314. The ReadyNas Duo Ultra r...
- Jun 24, 2017
Hi everyone for your answers ... so, I found a solution that works for now ... I disconnected ups from readynas duo and instead I connected it to RN 314! Always via USB and now it's handled properly ... I also tried to simulate a blackout and the NAS ran automatic shutdown when the battery of the add-ons was almost discharged.
Before I had thought of connecting it to RN 314 because I thought Nas would not support the connection with an UPS via USB.
Ultimately, the UPS EATON PRO 1200 would seem to be handled well by RN 314, unlike ReadyNas Duo and ReadyNas Duo Ultra!
Maybe the problem is the ReadyNas Frontview interface, while ReadyNas OS 6.X.X is all right ... but I can not say it with certainty.Thank you all.
Bye
Sandshark
Jun 23, 2017Sensei
UPS monitoring in the ReadyNAS is provided via NUT (network UPS tools). The NUT compatibility list, while listing the Elipse ECO, ASR, and MAX, does not list the Elipse Pro. Another user of this forum has reported a similar problem with an Eaton 5S, whihc is on the NUT compatibility list. I have an Eaton 5P and have no such problem.
I previoulsy searched for such instances in other forums and did find them for the 5S, with no resolution given. The conclusion in one was that there was a flaw in the Eaton USB communications. Whether this is also true for the Elipse Pro, I can't say, as I can find no messages about it and NUT.
bibo_net24
Jun 24, 2017Aspirant
Thank you all.
Bye
- SandsharkJun 24, 2017Sensei
The older NASes are going to have an older version of NUT included in their OS, so using newer model UPSes with them is going to be a gamble.
BTW, there is no such thing as a "Duo Ultra". If you mean an Ultra2 or Ultra2Plus, then that can be upgraded to OS 6.x, though it is not officially supported by Netgear.
