janforman's avatar
janforman
USB EXT2/3/4 format from Frontview on ARM
It's possible to add ext2/3 format for USB devices via Frontend?
Today I must use SSH access and mkfs on NAS or another Linux box.
-- i don't need any help, this is for information only --
Btw. ext4 have some performance issues over ext3 on SATA connected discs.
I don't use it because it's terribly slow when there are a lot of files on NAS.
EXT4 generates a lot of IO-Wait and kernel load over 12 when EXT3 on same data don't.
Looks like some journal problem, there's nothing in logs btw.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    So this is a Duo v2 (runs RAIDiator 5.3.x)?
    There is not the option to format a disk via the Dashboard at this time.
  • Formatting external backup disks with ext2/3 is a really bad idea unless the internal source disks use ext2/3, too.
  • I don't understand.
    RAID1 with system is mounted as ext3 now.
    /dev/md0 / ext3 defaults,noatime 0 0
    Only software RAID with data is ext4
    But this have heavy performance problems on nearly full volume with a lot of files (maybe some bug, don't know why).
    I reformat this to ext3 too, because it's much faster (except fsck of course).
    EXT2 is fastest for backup (NTFS is slow and I don't need journal on backups) anyway bad format ruins speed completely.
    mdgm-ntgr
    Well EXT4 has some nice features like support for volumes >16TB in size (though a factory default - wipes all data, settings, everything - is needed with disks in place for that) amongst other things. Now on a 2-bay desktop NAS you may feel that there's not as much benefit of using EXT4 as there would be on some other model ReadyNAS units.
  • I can swith EXT2/3/4 with data on, because I have EXT4 extended features off.
    But EXT4 is unusable because system is very heavy loaded, while EXT3 is fine.
    This looks like EXT4 don't perform well, when there are a lot of files and nearly full volume.
    (but it can be some sort of bug as I said)
    USB backup is a lot faster when ext2 is used, but disc must be formatted outside NAS or with SSH access to device.
  • ext2/3 uses a timestamp resolution of only 1 second while ext4 usees 1 nanosecond. Thus, incremental backups from ext4 to ext2/3 will not be incremental since the files on the target will (almost) always be older. E.g., see viewtopic.php?f=31&t=65736
  • StephenB's avatar
    It would be nice if the user could set the rsync time-window to 1 second on the backup job. Granted this should not be the default, since it is possible for file to be modified twice within a second. However, if the backups are generally done off-hours, then the odds are pretty small.
    mdgm-ntgr
    JohnnyB wrote:
    I do not understand why but rsync seems to work anyway: viewtopic.php?f=31&t=66167
    Rsync copies the changes to files across. It's a protocol designed for backups particularly over the WAN (internet).
  • StephenB's avatar
    Yes.
    Though I believe that the normal settings on the ReadyNAS tell rsync to ignore analyzing files if the timestamp, etc matches, correct?
    So without the "--modify-window=1" option, rsync would have to analyze every single file for changes, which will use a lot of computation and take more time.
    At least that is how it looks to me. Unless rsync is smart enough to do this on its own if the source is running ext4 and the sink is running ext3???
ProSupport for Business
