rmm1
Nov 05, 2011Aspirant
using the HDD from the Readynas Duo in a USB enclosure
I know there is a FAQ about using the ReadyNAS drives in another machine but is there a simpler way? I have read about http://www.chrysocome.net/explore2fs but have not tried this and besides can ...
PapaBear1
Nov 05, 2011Apprentice
If you are not concerned about the data, the drive can be connected to a Windows machine and formatted in the NTSF format. I have several older smaller drives retired from ReadyNAS use in use as spare Windows drives.
If you want to read the data outside the ReadyNAS box, or want to use it on an Linux system, then I will allow others to comment.
