chemist3
May 06, 2020Aspirant
Videos folder problem
HI, I'm an owner of a ReadyNAS 104 installed with 4 x 4tb HDD's and using the latest firmware 6.10.3 I have a problem with the videos folder and also the sub folders inside of it. the issue is ...
Sandshark
May 06, 2020Sensei
What method is the TV using to access the NAS? ReadyDLNA? Plex? It sounds like you need to run a database update on whichever it is. I don't run either, but somebody else is sure to know how to accomplish that if you post which you use.
