Miplo90
Mar 02, 2013Aspirant
Volume scan found and corrected errors...almost every day???
Hello,
I have a ReadyNAS Duo V2 with 2 hard drives: WDC WD30EZRX-00DC0B0 3TB in a RAID 1 configuration.
If I have do a volume scan of the disks (Shutdown ->Next startup a volume scan) I get almost always the message: Pass 1: Checking inodes, blocks, and sizes Inode 12648454, i_blocks is 686253560, 686253672 Should be. Fix? yes
And that 365 lines long with only blocks that are wrong.
Can someone give me an explanation of this
The discs are not even a week old.
Thank you.
Regards, Miplo
Thank you.
Regards, Miplo
- brinzleeAspirantHi Pimm
Sorry to hear that.....they did the same for me and asked me to return the unit. I received a new unit fairly quickly, of course plus additional postage to me...and that didn't fix the fault.
I think their is a firmware fault on the NAS (5.3.7) itself so maybe hang on a little......I'm sure your fault is identical to mine....are you using XRAID2 with your Western Digital WD30EFRX
What was the version of BIN file they sent you to remedy the situation.
I have just been sent another version and installed it and so far so good, no inode errors anyway!!....Maybe they are waiting for my feedback before they release it
Regards
Brinzlee - Miplo90AspirantHi Brinzlee
I have a new NAS received.
The RMA is handled very quickly but the problem has not been solved for me.
I think to, it is a problem in the firmware.
Pim Geurts - brinzleeAspirantHi Pimm
Thats a shame.......although as I mentioned earlier its the same thing that happened to me
Would you like me to send you the firmware update they sent me.....I think it has fixed my issue....It might be worth a try.....you install it like an addon
Brinzlee - Miplo90AspirantHello Brinzlee,
Of course you can.
Thank you very much.
Regrads,
Pim Geurts - brinzleeAspirantHi Pimm...
Did you have any luck with the firmware update on your system.....???
Regards
Brinzlee
