Nate_Cochrane
Dec 29, 2013Aspirant
WD 3TB recommendations for Pro Pioneer?
Hi I have a Pro Pioneer stacked with five WD RE4 drives (WD2003FYYS-01T8B0 and WD2003FYYS-02W0B0) and would like to start incrementing to 3TB WDC drives or greater starting from the sixth drive. ...
mdgm-ntgr
Dec 29, 2013NETGEAR Employee Retired
What disks did you have installed when you last did a factory default.
Be aware of two expansion limitations:
1. Cannot expand by more than 8TB, so if your volume capacity was 3.5 TB when you last did a factory default you cannot expand past 11.5 TB.
2. Cannot expand past 16TB. If you want a volume with greater capacity you have to do a factory default with the disks in place.
