Alebi1's avatar
Alebi1
WD Red NAS Hard Drive+ Neatgear Readynas NV+
Hello.
I bought a Netgear Readynas NV+ some years ago, and because of space I now need to upgrade the disks.
I have 4 pcs of Western Digital 4Tb (WD RED NAS Hard Drive)
Will this work with my Readynas nv+ ?
Its set up in X raid and I want to keep whats on the 2 tb already there.
Is it just to swap or do I need a firmware update?
Noob questions, but I really just bought this and have been a happy customer since..
  • Hey.
    I have the NV+ v1 (running 4.1.x firmware)
    This doesn`t support 4 tb ? Really... Isnt this just a Firmware update ,and then its done?
    If I have to buy a new one, which one do you reccomend?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    StephenB is correct. 2TB drives are the max supported by this unit. To use 4TB drives you would need a new NAS.
  • StephenB's avatar
    The RN104 is Netgear's current entry-level 4-bay NAS. It is much faster than the NV+
    The RN3xx and RN5xx are faster still.
ProSupport for Business
