acalvo
Jan 08, 2018Star
WD RED Smart bad info?
Hello community! Last April I bought two WD Red 4TB WD40EFRX hard drives (I bought them with a difference of 7 days) and replaced them with the two 2TB WD Green I had in the Readynas Ultra 2 with...
acalvo
Jan 10, 2018Star
First of all, thank you very much StephenB
Yes, I have SSH enabled, in readlity was the first thing I thought about checking it by command line. When I tried it via SSH I did it with this command:
smartctl --all / dev / sda
smartctl --all / dev / sdb
... and is similar to the information in the last SMART log of readynas
I contacted Western Digital to have the hard drives less than a year old (of the two year warranty they should have with Spanish law) and they came to tell me that it is likely to be an incompatibility with the device (a unconvincing answer) and to get in touch with Netgear.
After reading your message, I disconnected the readynas, and I took the sdb device and connected it by SATA directly on my computer (Intel i3570K with the motherboard Gigabyte GA-Z77X-UD3H) believing that maybe the readynas incorrectly reads the SMART from the hard drives. From Spain at least, I do not see the download in the link that you mention of Acronis, even so, I used a similar program that I use daily to check the SMART of the internal hard disks of my computer: CrystalDisk Info.
https://www.alvaro-calvo.com/forumpics/smart_sdb_wd40efrx_2.jpg
The information shown is a number of hours too low and similar to what smartctl showed me on the NAS, I insist on the last disconnection of readynas had 151 days of uptime, something I do not understand and more when they have worked almost always since April 2017 and we are in January 2018. A hard drive has been running one week longer than the other, that's fine; but I do not understand, reviewing the logs that I attached, as it is possible that above the 3600 hours approx. - 3700 hours approx. At some point the counters are reset at around 2500 hours and on the two discs "simultaneously" (it is true that smart logs are recorded once a week and this may happen to each disc on days other than the week, but it is clear that I suspect that they follow a pattern).
Could a supposed incompatibility with the readynas cause this failure in SMART? Because this happens on both hard drives. I honestly find it extremely strange, but I believe anything. I must say that the old WD Green that had 2TB (WD20EARS) have always shown correctly the number of hours in operation and have been 5 years without stopping.
Arrived at this moment, I am worried about the most important thing: the stored data, I do not know if I can trust the SMART of the hard disks (I have backup, but I am interested in the reliability of the NAS + hard disks).
What should I do? Change from NAS? Or is it impossible for the NAS to be the cause of the problem?
Thanks a lot!
Jan 10, 2018Guru - Experienced User
I don't see how. The drives are maintaining this data, and you are seeing the same low values when you do the readout on Windows with a different tool.
Also, lots of folks use these drives in Ultras, and I haven't ever seen this reported.
Without knowing the cause, it's difficult to say how big the risk is. You could try replacing one of the Reds with a Seagate Ironwolf I guess. That would reduce the exposure.
Another strategy is to run scheduled disk scrubs on the NAS - they do serve as good diagnostics, though it is tricky if you can't really on SMART.
- acalvoJan 17, 2018Star
Hello again.
I was talking in some emails with Western Digital, and finally, I made reference to this netgear thread: they phoned me, I insisted that the SMART should be autonomous of the device. They have insisted that hards disks work for them, unless the Western Digital tool (WD Data Lifeguard Diagnostic) says that the disks are in poor condition (and therefore the warranty could apply). They have told me that many incompatibilities can cause this type of events on the disks and that there aren't new versions of the hard drive firmware. Although it may be a bad read of the SMART in the NAS (I think it is false), I insisted that I read the SMART with CrystalDisk Info: They tell me that they trust this tool, but that the RMA is only provided in the disks if the Western Digital tool is used and indicates that the hard disks as failed.
I hope in the next few days to stop the ReadyNAS and check the hard disks again (I'll post it in this thread of the Netgear community). However, I don't have rare software combinations (I have the latest official software version of the ReadyNAS Ultra 2: Raidiator, OS6 has never been installed), I can provide the logs by private message to a moderator / administrator of the forum if necessary.
However, the BIOS of the ReadyNAS Ultra 2 has never been updated, I do not think this is a problem for the SMART to increase the hours correctly. The bios_ver.log file indicates the following: 09/08/2010 ReadyNAS-ProUltra2 V1.4;
and apparently there is a new version 11/02/2011 ReadyNAS-ProUltra2 V1.8. Are there any details of what problems are patched? Should I update it? I understand that this BIOS update is completely manual and is not mandatory ... because automatic updates have never suggested it. Is there a reason?Many thanks again.
