atz6975
Sep 20, 2008Guide
WD10EACS: Huge Load cycle count [ NOT SOLVED] in 4.2.9
Hi,
could ze jedis give their opinion on the following situation:
While checking my smart values after a forth drive expansion (4x1TB) I found that my three other drives that are 7 months old have +200 000 Load Cycle Count
While checking some forums, I find that this situation is somehow disturbing, at least confusing...
It is stated that :
1) This kind (wd gp) of drives is designed for 300k-500k Load cycle count
2) Many Linux environments generate very high Load cycle count and are worried about
such counts growth (76+ / hour)
3) WD has issued a WDIDLE3 DOS only, SATA only, tool that can enable/change timer/disable the current default 8s timer for Intellipark.
4) This could also somehow be achieved with hdparm
5) Some Unix HD flushing mecanism must also be considered
Please, please, please, as you now that many of us are happy (even with spin down off) Users of such disk, could you create an add-on or fix or statement on how to avoid this situation.
I'm more than ready to disable "intellipark" and run WDIDLE3 on many, many, many drives.
....or to run away from these drives (although $$$$ losses will hurt)...
To all wd10eacs and other wd gp drive users please post your Load Cycle Counts (LCC) here to help asses the situation.
Thank you.
Raw Read Error Rate 0
Spin Up Time 7725
Start Stop Count 834
Reallocated Sector Count 0
Seek Error Rate 0
Power On Hours 4995
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 9
Power-Off Retract Count 7
Load Cycle Count 218854
Temperature Celsius 34
Reallocated Event Count 0
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Multi Zone Error Rate 0
ATA Error Count 0
It is stated that :
Thank you.
- snipesAspirantThey still climbed by ~30 in an hour. Since the LCC count was already so high I decided to just disable and stop it where it currently is.
- rstoneAspirant
snipes wrote: I tried using the max timer value of 25.5 seconds with wdidle3
For those of you who don't have the software mentioned by snipes and others...I found a site that has the dos utility
ftp://76.17.197.241/public/software/dos/utilities/
Good Luck! - snahlGuideFixed the high LC count (LCC) on four of my WD10EACS-00ZJB0 by using 'wdidle3 /D'.
LCC counts are now stable.
As of today one can download 'WDidle3.exe' from the URL below:
http://home.arcor.de/ghostadmin/wdidle3_1_00.zip
Hope this helps someone. - snahlGuideForgot to mention that after disabling the idle timer (option /D) the temperature of all 4 disks averaged lower at 33°C / 91°F.
This temparature reading was taken immediately after copying 6.3GB of data onto the drives of my NV+.
Before the temperature averaged around 39°C /102.2°F - DrieStoneAspirantI too have a WDC WD10EADS-00M2B0 with high Load Cycle Count. I don't even know where I'd get ahold of a PC with SATA as I'm a Mac guy and only have laptops here. I don't suppose I can run the WD util on a drive over USB?
- BigbearfAspirant@DrieStone
I am a Mac guy also but it is so much easier to use an old Windoze machine and IDE to SATA adapter to perform the Dos fix. Kind of like using a flat head screwdriver on a phillips head screw. :D
Hope this helps.
bigbearf - atz6975GuideHi,
As far as I'm concerned issue is solved in 4.2.9.
As of yesterday my load cycle count is stable (just under 500k !!!) for older WDC WD10EACS-00ZJB0 drive. Drives WDC WD10EACS-00D6B0 were never affected and continue to be stable.
So much for accurate release notes...
...but thanks anyway.
ps: when is this available for NV+? - atz6975GuideBack to not solved.
My fault, I had activity (almost invisible) but as soon as that activity stopped the count went up again... - zvunksAspirantHi, you can download an ISO image with bootable FreeDOS and wdidle3.exe tool on it
http://tibi78.dyndns.org/wordpress/2011/07/wd-load-cycle-count-issue/
... follow the instructions.
I needed to deactivate this future due fact that i'm using several WD Green hard drives on Network Attached Storage, and LCC incresead dramaticaly.
I've tried Blue, Green and Black, 2,5 or 3,5 inch drives, all of them had this problem on linux, and fixed with wdidle3 tool.
If i used the hard drive in an external closer for backups porposes, i used the deafult timer setting.
Backup important data prior using wdidle3 tool!and use it on your own risk.
