NAS_t
Aug 13, 2009Aspirant
WD10EADS WD Caviar Green - 1TB >> excessive Load Cycle Count
I have two WD10EADS 1TB drives in my Duo. The first was installed a months ago as Drive 2, mirroring the 500 GB Seagate that came with the Duo. The WD drive seemed to work just fine, so I recently bo...
shanaclan4
Sep 30, 2009Aspirant
You might want to consider the WDIDLE3 utility as documented here: http://www.readynas.com/forum/viewtopic.php?f=64&t=32319&p=184386&hilit=WDIDLE3#p184386
I am using different WD Caviar Green drives known to have high LCC issues and have run the WDIDLE3 to disable the Idle Park feature (IntelliPark). My LCCs are holding steady.
If you decide to tweak, let us know how you get on with the change.
