NAS_t
Aug 13, 2009Aspirant
WD10EADS WD Caviar Green - 1TB >> excessive Load Cycle Count
I have two WD10EADS 1TB drives in my Duo. The first was installed a months ago as Drive 2, mirroring the 500 GB Seagate that came with the Duo. The WD drive seemed to work just fine, so I recently bo...
fmantek
Dec 07, 2009Aspirant
I am just coming about this thread, as i installed a few more WD Green drives (1.5TB) in a new NVX unit and saw that WD special bin i can download.
Now, on a NV+ unit, that is using 4 WD Green 1TB drives (all the same part numbers), i see the following (at the end):
11440 power on hours
684276 LLC count
That is an avg. of 60 LLCs per hour. So far the drives report no other issue (like sectors defect etc). They are just happy as can be.
Not sure if there was ever an official answer if the high LLC count is, in fact, a problem. But if so, it seems to take a while.
Frank
Model: WDC WD1000FYPS-01ZKB0
Serial: WD-WCASJ1740341
Firmware: 02.01B01
SMART Attribute
Raw Read Error Rate 0
Spin Up Time 7741
Start Stop Count 108
Reallocated Sector Count 0
Seek Error Rate 0
Power On Hours 11440
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 108
Power-Off Retract Count 139
Load Cycle Count 684276
Temperature Celsius 41
Reallocated Event Count 0
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Multi Zone Error Rate 0
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 0
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
684276 LLC count
Frank
Firmware: 02.01B01
SMART Attribute
Spin Up Time 7741
Seek Error Rate 0
Spin Retry Count 0
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 0
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
