whytega
Jul 31, 2012Aspirant
WD20EFRX - WD Red with DUO v1
I see some interest in this drive working on the DUO v1 and thought my recent experience could be useful. Other threads reference this topic but are slightly off from the original titles so I hope sta...
Sep 03, 2012Guru - Experienced User
They are not on the HCL yet, apparently they are being tested.
whytega is running them on his duo (per the signature line above), and there are some folks running the 2 TB version on NV+ (though only the 1TB model is listed)
Though you risk losing support, in my view these are still the best WD drive option for 2 TB. The WD2002FAEX is the only other one I'd consider, and it is quite a bit more expensive.
