whytega
Jul 31, 2012Aspirant
WD20EFRX - WD Red with DUO v1
I see some interest in this drive working on the DUO v1 and thought my recent experience could be useful. Other threads reference this topic but are slightly off from the original titles so I hope sta...
harleyknutte
Feb 08, 2014Aspirant
Today I upgraded and expanded my two 500GB drives with two WD20EFRX with no issues. Hot swap one disk at a time (once synchronized) two reboots and everything works! Amazing, thank you Netgear! The local supplier should have a HCL disk in stock but when I got there, it showed that it been replaced by another disk not on the HCL so I decided to try the WD20EFRX, which seems to work. I can warmly recommend it. It worked just like it should!
