Jobbigvolvo
Jun 16, 2011Aspirant
WD30EZRX Any problems ?
Its not on the official compatibility list ofc, but im hoping thats just a matter of time.
Tho a confirmation from someone thats actually tried one would be much appreciated.
This is for an Ultra4 plus with fresh firmware btw.
I'd get the officially approved if possible ofc, but manufacturers change versions faster then they get tested it seems.
/Regards
/Regards
- rwolfe12AspirantThank you NASable. I followed your link to the tool, and will see if I can find a download for the same utility that is the right one for my drive. There was a big cautionary message about not using it on any drives not on the list.
Physically, do I need to put the drive into my PC to do this? That's what it seems to imply, but I'll go get the tool first and do a little RTFM.
Cheers,
Ron - rwolfe12AspirantI went to WD's comparable page for my drive (the Caviar Green 3TB Model WD30EZRX) and it does not show a similar tool. Hmmmm.
Here is what is listed:
•Acronis True Image WD Edition
•Advanced Format Software
(Only for Windows XP users with WD Advanced Format Drives)
•Data Lifeguard Diagnostic for DOS
•Data Lifeguard Diagnostic for DOS (CD)
•Data Lifeguard Diagnostic for Windows
I guess I'll give it a try without changing anything and see how things go. - gabortAspirantOK, so what's the deal with the WD30EZRX drives? They're still not on the compatibility list.
What makes this more serious than before, is that the previous model (without the 6Gb Sata) is now no longer available.
Time has not stopped NetGEAR, try and do something about this please! - tcdmailAspirant+1, please verify if this drive is compatible or not as told above the previous model can't be bought anymore.
- PeterKocicAspirant+1 I'm about to order and can only order EZRX so have to go with that :S
- PeterKocicAspirantWell
Here's what I did.
I bought 4 x EZRX discs and I set up my new Ultra 6+ with zero problems so far.
It's amazing how quiet the Ultra 6 is and there's no noise what so ever from the discs.
I've used wdidle3.exe /d
I'll keep you posted here if anything changes. - VuzrakAspirantIs widdle a requirement because I don't currently have access to a machine with a sata connection to run it.
- AmienAspirant
Vuzrak wrote: Is widdle a requirement because I don't currently have access to a machine with a sata connection to run it.
I would like to know this too - sdchewAspirantI'm running the 2 TB version (WD20EARX) for about 7 months now. No issues whatsoever. Curious about whether the idle setting is needed too. Or is it unique to the 3 TB drives? Note that I don't enable spin down on the NAS
- AmienAspirant
sdchew wrote: I'm running the 2 TB version (WD20EARX) for about 7 months now. No issues whatsoever. Curious about whether the idle setting is needed too. Or is it unique to the 3 TB drives? Note that I don't enable spin down on the NAS
http://www.youtube.com/watch?v=gqY5zlCXQmU
this explains it very good
