ilansch
Dec 06, 2016Aspirant
Where are the system logs
Hi, I am running a certain demon on a ReadyNAS OS 6.5.1 machine. The demon print logs, usually the logs are located at: /var/log/messages or /var/log/syslog. Where is does the logs output in re...
- Dec 06, 2016
We use systemd. You can use the journalctl command
mdgm-ntgr
Dec 06, 2016NETGEAR Employee Retired
