NilsG's avatar
NilsG
Which gigabit netgear switch is best for jumboframes ?
I now have three GS608 v3 (gigabit and 9000 jumbo support) that seems to do the job well - is there better alternatives that will handle jumboframes better and give faster transfers ? (Before I had FS608 v3 (100mbit) switches that were maxed out during NAS to NAS transfers)
Any suggestions ? and preferrably unmanaged switches - already using far too much time adjusting and fine tuning thingys in my house !
TIA
  • Just wonder - can slower reads vs writes be due to the nature of x-raid2 ? and not to forget the disks - spinning disks are slower on writes
    EDIT_ IS my ultra6 slow ? or is this speed what I can expect in a enviroment like mine ?
  • StephenB's avatar
    EDIT_ IS my ultra6 slow ? or is this speed what I can expect ?
    Writes to a Raid array require more I/O (which slows things down) but can be queued (which can speed things up).
    Do you test with the settings I suggested (disk caching on, and journaling disabled)?
  • StephenB wrote:
    Yes Sir - am I slow ?
  • StephenB's avatar
    The 850 down seems about right, the 520 up seems a bit slow. Not horrible performance, but I'd expect something a bit faster. Are you perhaps using dual-redundancy?
  • I have a new 516. For me both 1500 and 9000 MTU basically fills gigabit network (125 MBYTE per sec). Oddly enough enabling Gigabit gives med lots of errors so I run with 1500. Switches are two GS108Tv2. I'm going to try teaming once I get a new GS116E (out of ports right now). Anyone else since problems with Gigabit and lots of errors?
  • Sorry for late reply ; no I am not using dual redundancy. As I am writing this I am starting to replace 3 of the WD30EFRX drives with WD40EFRX.
    I did a factory reset with three of the WD30EFRX removed (three in) - and it' s now at the end of restriping disk #3 atm
    All three WD40EFRX are checked with WD's Data Lifeguard Diagnostic and found ok.
    Configuration: RAID Level X-RAID2, 3 disks
    Status: Restriping 97% complete, Time to finish 18.0 min, Speed 67.2 MB/sec
    A failed WD30EFRX drive has been returned (got my money back) - and the two other WD30EFRX I don't use in Ultra6 anymore will go into my 2bay Qnap TurboNAS.
    Will do a new speedtest when everyting is up running - somehow I don't expect a faster system with WD RED's vs. WD Green's
  • StephenB's avatar
    Sounds like all your drives are Reds, so I am puzzled by the last comment.
    However, I agree that speed should be pretty similar between the Red models and the Green models. The technical advantages are more about being RAID-friendly (vibration control, tler, etc), and of course there is the 3x warranty period.
ProSupport for Business
