samuk
Oct 19, 2011Aspirant
Which HDD for my Ultra4
Hi,
I needed something quite and energy efficient, speed would be good as i dont want anything too slow.
I was thinking of the Green 2TB HDD's, though these are 5400rpm..will this be too slow?
or would you recommend something different?
http://www.ebuyer.com/264274-wd-2tb-3-5 ... e-wd20earx
- StephenBGuru - Experienced UserFolks are using this drive successfully. Though it is not presently on the hardware compatibility list, which means that you won't get Netgear support on disk-related problems. Netgear hasn't said if the drive has issues, or if they simply haven't tested it. Personally I wish they would as the older EARS (which is on the list) is no longer being produced.
The HCL is found here: http://www.readynas.com/?page_id=82
There might be a slight slowdown with a 5400 rpm drive, though in practice the disk transfer speed is very close to what you can get on a single gigabit connection anyway. - samukAspirantJust found out i already have one of these in my NAS box, however now discontinued.
http://www.ebuyer.com/product/171763
So shall i buy 2 more of these to complete the RAID 5 setup?
http://www.ebuyer.com/191465-hitachi-ul ... 2050cla330
Would there be a performance increase if i went for SATA 3? - StephenBGuru - Experienced UserThe idea with rotational safeguard is that the vibration of nearby disks can throw the heads off-track. The safeguard is a sensor arrangement in the disk that detects the external vibration and compensates for it. It has nothing to do with acoustic noise. I'm not sure how much a difference it actually makes.
5400 rpm drives are a bit slower, if you install the earx into your desktop you will see speeds around 100 megabytes a second. They are of course cheaper, use less power, and run cooler. Folks here indicate the the performance drop is relatively small (maybe 10% at most).
You will see no performance boost with SATA 3. There aren't any mechanical drives that are fast enough to outpace SATA 2.
Whether 3 TB drives are worth the extra expense is an interesting question.
-On new installations, you need fewer drives to get the same space. Drives fail of course. If reliability is equal you will need fewer replacements over time if you go with fewer large drives. Since 3TB prices are dropping this could save you money in the long run. Also, if you leave a spare slot then you can add capacity without needing to discard/re-purpose a working smaller drive.
-On upgrades, once the chassis is full your only option is to replace a smaller drive with a larger drive. If you have 1 TB drives today, it is already about the same cost (per added gigabyte) to upgrade to 3 TB instead of 2 TB. If you have 1.5 TB drives today, it is actually cheaper (per added gigabyte) to upgrade to 3 TB.
Overall, I figure its a wash today with the cost advantage shifting to 3 TB soon. With my pro 6, I had four 1.5 TB drives already in hand, I augmented that with 2 3TB drives. (The 3TB are 5400 rpm btw). As the 1.5 TB drives age, I'll replace them with 3 TB. - samukAspirantThanks for all the info, what are your thoughts on this
I currently have one, and the NAS box is noisy, though i am not sure if it the drive or the fan actually..anyway i think i will be shifting this to the loft.
I would i spouse make more sense to match what i have rather then miss-match..
Any yes i could upgrade to a larger capacity later. I have hit the 2TB mark, so putting 2 disk will give me another 2TB..this should last me 3 odd months.
