Ridcully's avatar
Ridcully
Which unit to upgrade to?
Currently have an NVX with 4*2TB onboard and its full.
I was going to buy a pair of 4TB and then later on buy another pair, using auto expansion, as I have already done this when I went from 4*1.5 to 4*2. However if I understand correctly there is an issue with doing this.
I don't understand the current range so any suggestions. Primarily used for DVD ISOs and is connected to a Netgear Neo550. Blu-ray rips likely in the future if that makes any difference.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    The ReadyNAS RN314 would be a good choice for your needs I think. If you would like more than four drive bays perhaps the RN316.
    The ReadyNAS RN516 would be a good choice if you need to transcode 1080p video (convert it on the fly from one format to another e.g. to stream a 1080p MKV to an iPad using Plex)
    Do note that you will need to put your new disks in the new NAS and transfer your data e.g. across your network.
  • Not understanding the product range, what's the advantage of the 314 over the Ultra 4 / Ultra 4+. Also whats the EDA500 thing for the greater capacity?
    mdgm-ntgr
    The RN314 is a new product. It runs a new OS, ReadyNAS OS 6 and uses the btrfs filesystem and a newer kernel.
    The RN314 has a couple of eSATA ports and a HDMI port.
    The Ultra 4 and Ultra 4+ are discontinued products. The focus going forward will be on the new models.
    The EDA500 is an optional 5-bay expansion chassis that connects to an eSATA port on the RN314. If you purchase an EDA500 you could create additional volumes using the disks in the EDA500.
ProSupport for Business
