cstern
Sep 13, 2011Aspirant
Can't login from Mac (10.7.1 Lion)
After having waited for a long time for first a new firmware for my NVX, and then a new client for my Mac running MacOSX 10.7.1 (Lion), I could go on using RNR - at least so I thought. I have insta...
jzeimet
Sep 14, 2011Aspirant
I had the same problem and got a hint by Justincbeck: Install tuntap virtual network driver and it will work immediately!
By the way, I'm only running smb (you can set this at the rnr properties/connection settings page). Port forwarding and automatic proxy detection is also enabled.
Works like a charm. Thanks to justin again!
