cstern
Sep 13, 2011Aspirant
Can't login from Mac (10.7.1 Lion)
After having waited for a long time for first a new firmware for my NVX, and then a new client for my Mac running MacOSX 10.7.1 (Lion), I could go on using RNR - at least so I thought. I have insta...
ckstaley
Jan 23, 2012Aspirant
mdgm wrote: nicolaban this thread as been dead for months. Would've been better to open a new thread. The Lion update was released well after the previous post in this thread. So the workarounds mentioned in this thread are not needed.
What version of the ReadyNAS Remote software did you install? Have you tried rebooting after installing the update.
Not true, mdgm!! You know not of what you speak.
It's Jan. 22, 2012. I have the latest version of Lion (10.7.2), the latest version of ReadyNASRemote on my MacBook Pro (1.0.27), the latest version of ReadyNAS Radiator on my Duo (4.1.8 ), and the latest version of ReadyNAS Remote on the ReadyNAS Duo server (v1.0.9.78)...
... and STILL I found that I had one shot at ReadyNAS Remote working on my MacBook Pro. After that, I had to completely uninstall it (including system files) and re-install it only to have it work just once more. If I quit the app, it would always give me the "login failed" message.
Finally, I found this thread and installed TunTap. I have no idea what it fixes that Netgear can't seem to fix, but it just plain simply works . . . over and over and over again . . . IT WORKS!!!!
Thank you jzeimet for telling us the hint by Justincbeck!
Any others having this kind of problem, here's the URL again...it just works!: http://tuntaposx.sourceforge.net/
