tarobun
Nov 24, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091.
If it doesn't work after installation, try rebooting.
Not sure if it can be install over the top of super-poussin's version, but if you are planning on uninstalling super-poussin's version then remember to save the torrent files somewhere else first.
To quote myself:
Thanks to super-poussin for the original Transmission add-ons.
Enjoy!
Transmission_2.73.bin - http://www.mediafire.com/?ajpyyc7ujv54o37 no-utp
Transmission_2.75.bin - http://www.mediafire.com/?gbmbhu3hrabf9fe
Transmission_2.76.bin - http://www.mediafire.com/?389i53w9w9rtosm
Transmission_2.77.bin - http://www.mediafire.com/?pm420vuajaim9bz
Transmission_2.80.bin* - http://www.mediafire.com/?5s7dag8ko72doj1
Transmission_2.81.bin* - http://www.mediafire.com/?x4pvvidrgb36df2
Transmission_2.82.bin* - http://www.mediafire.com/?rbctsdae000zoav
Transmission_2.83.bin* - http://www.mediafire.com/?31iul25i0t12qda
Transmission_2.84.bin* - http://www.mediafire.com/?rh5fge4mc8ahzw4
*if the "Upload" button doesn't work or the "Destination folder" field is blank, reload the webpage.
To quote myself:
tarobun wrote: It looks like upgrading from Transmission 2.42 to this Transmission add-on is a no-no. Sounds like there are conflicting configuration that screws up both installs. :( (eg. /c/addons-config)
It seems the best approach is to fully uninstall the old, delete the config directory, and then install this add-on. Once you're on this add-on, updating is straightforward and can be done over the existing version.
Just a fyi - the default download dir is /var/local/Downloads and there is no username and password with this add-on. If you are prompted for them then the old version was not fully uninstalled.
Enjoy!
- etonLuminary
tarobun wrote: Looks fine.... so what's the problem you're seeing?
Hmm, strange.
The problem is that Transmission doesn't start. And I can't access the web gui. But after I executed your commands Transmission read the settings and encrypted my password. So something has changed. But it still don't work.
It might be better to start all over. How do I get rid of Transmission completely? Will it be enough to remove the add-on from Frontview and then the rest that is left of these:# find / \( -path '/c' -o -path '/USB' \) -prune -or -iname '*transmission*' -exec ls -ld {} \;
-rw-r--r-- 1 admin admin 206 Aug 10 2013 /etc/frontview/apache/addons/TRANSMISSION.conf
drwxr-xr-x 4 admin admin 16384 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION
-rw-r--r-- 1 admin admin 437 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/language/en-us/TRANSMISSION.str
drwxr-xr-x 3 admin admin 16384 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/web/style/transmission
-rw-r--r-- 1 admin admin 43146 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/web/javascript/transmission.js
-rw-r--r-- 1 admin admin 1334 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/TRANSMISSION.html
-rw-r--r-- 1 admin admin 8135 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/TRANSMISSION.js
-rw-r--r-- 1 admin admin 488 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/TRANSMISSION.xml
-rwxr-xr-x 1 admin admin 2743 Aug 10 2013 /etc/frontview/addons/ui/TRANSMISSION/TRANSMISSION_HANDLER.pl
drwxr-xr-x 2 admin admin 16384 Oct 28 2012 /etc/frontview/addons/bin/TRANSMISSION
-rwxr-xr-x 1 admin admin 588300 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-daemon
-rwxr-xr-x 1 admin admin 615028 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-remote
-rwxr-xr-x 1 admin admin 580228 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-create
-rwxr-xr-x 1 admin admin 580128 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-edit
-rwxr-xr-x 1 admin admin 580168 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-show
-rwxr-xr-x 1 admin admin 580016 Aug 10 2013 /etc/frontview/addons/bin/TRANSMISSION/transmission-cli
-rw-r--r-- 1 admin admin 825 Apr 29 01:11 /etc/frontview/addons/TRANSMISSION.remove
drwxr-xr-x 5 root root 16384 Apr 29 16:06 /root/.config/transmission-daemon
-rwxr-xr-x 1 root root 7593660 Oct 31 2011 /usr/local/bin/transmission-cli
-rwxr-xr-x 1 root root 7808113 Oct 31 2011 /usr/local/bin/transmission-create
-rw-r--r-- 1 root root 6095 Jan 14 2009 /usr/local/man/man1/transmission-remote.1
-rw-r--r-- 1 root root 2964 Jan 14 2009 /usr/local/man/man1/transmission-daemon.1
-rw-r--r-- 1 root root 3838 Jan 14 2009 /usr/local/man/man1/transmissioncli.1
-rw-rw-rw- 1 root root 5 Apr 29 16:12 /var/run/TRANSMISSION.pid
-rw-r--r-- 1 root root 8644 May 1 14:00 /var/tmp/transmission.log
Or do I have to tinker with some other files?
And what is /root/.config/ ? - tarobunTutorLooks like there are some old transmission files:
Best way to start again is to install the same add-on and then uninstall it. It should remove all related add-on files.
The /root/.config/transmission-daemon is the default location of the config files if you do not specify the TRANSMISSION_HOME env variable. You can safely delete this directory. - etonLuminary
tarobun wrote: Looks like there are some old transmission files:
I actually did install and uninstall super-poussin' and WhoCares' Transmission versions before installing your version. But now I went through that procedure again. Uninstalled yours, installed WhoCares' version and uninstalled it, installed super-poussin' and uninstalled. But these files remains:# find / \( -path '/c' -o -path '/USB' \) -prune -or -iname '*transmission*' -exec ls -ld {} \;
drwxrwsr-x 2 root admin 16384 May 4 10:34 /etc/transmission-daemon
-rw-r--r-- 1 nobody nogroup 6 May 4 10:44 /var/run/transmission-daemon.pid
Can those files be safely deleted? - etonLuminaryUpdate. I deleted the files listed above (also /c/addons-config/Transmission) and after that the installation of tarobun's Transmission went just fine!
- etonLuminaryFeedback.
The fresh install of tarobun's version of Transmission has been working quite well. But downloaded torrents often gets tracker errors. So I can't seed them. The only way I've found working to repair that is to restart Transmission from Frontview, tedious. Is this just my NAS or does others experience the same thing with their installations. This problem was rare with super-poussin's version.
MessageError: Tracker: Could not connect to tracker
- tarobunTutorUpdated to version 2.83
Changes:
All Platforms- Licensing change: the GNU GPLv2 code can now be used under GNU GPL v2 or v3
- Fix network hanging issues that could occur when both UTP and DHT were enabled
- Fix 2.82 file descriptor leak when importing a blocklist
- Disallow torrents that contain "/../" in the path
- Fix 2.82 bug that didn't retain peers between sessions
- Fix potential dangling memory error in UDP tracker DNS lookups
- Remember a torrent's "queued" state between Transmission sessions
- Updated third party libraries: DHT updated to v0.22; miniupnpc updated to v1.9
- Autoconf script fixes: better detection of ccache, minupnpc
- Fix the X-Transmission-Session-Id header to be valid with the SPDY protocol
- Fix thread safety bugs in the tr_list datatype
- When determining free disk space on NetBSD>=6, support its Quota feature
- Windows portability improvements
Daemon- Use libevent's event loop
- Fix discrepancy in curl SSL setup between tr-daemon and tr-remote
Web Client- Support file renaming in the web client
- Fix incorrect torrent state being displayed for magnet links
- Make URLs in the torrent's comment field clickable (and sanitize them to prevent cross-scripting)
- etonLuminaryThanks for the new version tarobun!
Just updated, wokring fine. - vatazhkaAspirantTransmission 2.83 is vulnerable to peer communication vulnerability. More details are available in Gentoo bug tracker at https://bugs.gentoo.org/show_bug.cgi?id=516822. Version 2.84 contains fix for this vulnerability.
- tarobunTutorThanks!...
Updated to version 2.84
Changes:
All Platforms- Fix peer communication vulnerability (no known exploits) reported by Ben Hawkes
- emk1AspirantAnyone else having watch-dir issues with 2.84? Seems any torrent files dropped in my watch-dir aren't being loaded. Was working on 2.83 and earlier.
