alouch47's avatar
Sep 16, 2010
PHP VirtualBox Manager (Help)
Hi all.
"WhoCares?" if you're around, maybe you can help me with this.
I've installed you addon and once made it works, but by the time VB wasn't working.
(VB installed trough APT)
Now that my VB is working (VB installed from sources), the addon not working :/
The strange thing is that when VB was working (it was working but VM cannot run) I can connect to PHP VBox manager without changing the pass in the config file. If I change the pass, your addon wasn't working.
Now that my VM are working, whether I change the pass in the config file, or not, I cannot access your addon.
It output the following error message :
Exception Object
[message:protected] => Error logging in or connecting to vboxwebsrv.
[string:private] =>
[code:protected] => 32
[file:protected] => /frontview/ui/resource/html/phpvboxmgr/lib/vboxconnector.php
[line:protected] => 117
[trace:private] => Array
[0] => Array
[file] => /frontview/ui/resource/html/phpvboxmgr/lib/vboxconnector.php
[line] => 1749
[function] => __vboxwebsrvConnect
[class] => vboxconnector
[type] => ->
[args] => Array
[1] => Array
[line] => 218
[function] => getVMsCached
[type] => ->
[args] => Array
[0] => Array
[fn] => getVMs
[1] => Array
[data] =>
[errors] => Array
[persist] => Array
[2] => Array
[function] => __call
[type] => ->
[args] => Array
[0] => getVMs
[1] => Array
[0] => Array
[fn] => getVMs
[1] => Array
[0] => Array
[data] =>
[errors] => Array
[persist] => Array
[3] => Array
[file] => /frontview/ui/resource/html/phpvboxmgr/lib/ajax.php
[line] => 93
[type] => ->
[args] => Array
[0] => Array
[fn] => getVMs
[1] => Array
[0] => Array
[data] =>
[errors] => Array
[persist] => Array
I have enabled log on the vboxwebsrv.
The log is :
2010-09-16 16:53:45 [ P ] Socket connection successful: host = default (localhost), port = 18083, master socket = 9
2010-09-16 16:54:09 [ P ] Request 1 on socket 10 queued for processing (1 items on Q)
2010-09-16 16:54:09 [ 1] New SOAP thread started
2010-09-16 16:54:09 [ 1] Processing connection from IP=127.0.0.1 socket=10 (0 out of 1 threads idle)
2010-09-16 16:54:09 [ P ] Request 2 on socket 11 queued for processing (1 items on Q)
2010-09-16 16:54:09 [ 1] Processing connection from IP=127.0.0.1 socket=11 (0 out of 1 threads idle)
2010-09-16 16:54:10 [ P ] Request 3 on socket 10 queued for processing (1 items on Q)
2010-09-16 16:54:10 [ 1] Processing connection from IP=127.0.0.1 socket=10 (0 out of 1 threads idle)
2010-09-16 16:54:10 [ P ] Request 4 on socket 11 queued for processing (1 items on Q)
2010-09-16 16:54:10 [ 1] Processing connection from IP=127.0.0.1 socket=11 (0 out of 1 threads idle)
2010-09-16 16:54:10 [ P ] Request 5 on socket 10 queued for processing (1 items on Q)
2010-09-16 16:54:10 [ P ] Request 6 on socket 11 queued for processing (1 items on Q)
Can you help me ?
Thanks.
ProSupport for Business
