cat509
May 30, 2013Tutor
Plex question
Would someone be able to tell me where the Preferences.xml for Plex is located? I'm using readynas os6. Thank you!
- GovnahAspirantroot@ReadyNAS_516:/apps/plexmediaserver/MediaLibrary/Plex Media Server#
- cat509TutorGovnah,
Thank you!! When I try to cd \ into that directory though it says that the Plex Media Server directory doesn't exist. I think I have stopped the server with the ctl stop etc. When I do a ls Plex Media Server is in the MediaLibrary. Any suggestions or instructions? - btaroliProdigyWell, I see your profile says you're using a Duo... runs very different OS than the RN516 that Govnah is using. The base path for 4.x (and as far as I know 5.x) OS'es is /c/.plex/
On my Pro 6 (4.2.22), I found it at /c/.plex/Library/Application Support/Plex Media Server/Preferences.xml
Indeed, on my RN516 (6.0.6), I did find it at /apps/plexmediaserver/MediaLibrary/Plex Media Server/Preferences.xml - mdgm-ntgrNETGEAR Employee Retiredbtaroli, cat509 did claim to be using OS 6 in the first post so I assume he has a new NAS.
cat509 you need to escape the space e.g.
# cd /apps/plexmediaserver/MediaLibrary/Plex\ Media\ Server
Or try
# cd "/apps/plexmediaserver/MediaLibrary/Plex Media Server" - cat509Tutorbtaroli have a new 312 that runs os 6. I forgot to change that in my profile. But it was exactly where you said it would be. Thanks again for your help!
mdgm thank you for your help as well. Your line did the trick. I was able to edit my Preferences.xml and now can get in to my Plex Media Server again.
Thanks again for everyone's help!!
