revvin76's avatar
revvin76
ReadyNAS iSCSI Initiator - setup
Hi there
I have a Windows SBS Server 2k11 and a ReadyNAS DUO. I need to set up Windows Backup to use the ReadyNAS, and the only way it seems possible, is to install and setup an iSCSI initiator addon.
I have installed "EnableRootSSH_1.0.bin" successfully and can Telnet onto the DUO.
I have installed "iSCSItarget_1.4.20.2-readynas-1.0.5.bin"
Updated Raidiator to "RAIDiator-4.1.8".
I have followed the guide found here: http://readynasfreeware.org/projects/nas-iscsi-target/wiki/New_Version
and have created an 800Gb file ready to be connected to.
The iSCSI daemon is running i think.... when i issue the start command on Telnet I just get:
Starting iSCSI Target: ietd.
When I start the initiator on Windows, and add the portal to the "Discovery Portal" section... it just fails to detect a target?
I cant seem to find any documentation on installation or troubleshooting this addin - and it was last updated nearly 3 years ago - so I came on here hoping somebody might have some experience with the addon?
Thanks in advance
Kev
  • Anybody else perhaps have any suggestions? I am sure its probably something simple I have missed - but i have no prior knowledge of any of this unfortunately :(
    Anybody able to help me troubleshoot why the service doesn't seem to be starting on the ReadyNAS? Is it something I have done with the config file? Perhaps the IQN needs to be resolvable over the internet?
    Should it work in a closed environment?
    I can ping the ReadyNAS, and SSH onto it from the Windows Server. I suspect the issue is something stopping the service starting on the ReadyNAS - but with pretty much zero knowledge of Unix/Linux commandline I really have no idea where to start? :(
    Thanks guys
    kev
  • Just wanted to say a big thank you publicly to mdgm who resolved this issue for me and I now have a fully functional iSCSI service on my ReadyNAS Duo :)
    There was a rogue process running still, which when killed, allowed everything to start properly.
  • Hi Guys!
    Two Weeks ago i get my new ReadyNas Duo V2. I thought that i could use it for saving some of my files with an backup job. So i installed the HDD. but as i searched for an iscsi options i don't find anything. So i try to get help in our www. and thanks to google i found you. I download the files you talked about but when i try to install this addons on my nas i get an error message Architecture is bad.
    My Firmware is the latest one: Raidinator 5.3.6
    Has anyone an idea how to get this thing work as an iscsi target?
    Please let me know!
    Thx
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    The iSCSI add-on is for the Duo (v1) not the Duo v2. That's why it won't install on your Duo v2.
  • Okay thats the problem! Is there any way to get the iScsi target worked on an duo v2?
  • I don't think the Home units support iSCSI. You need to look to Pro range.
    Rgds Marto
  • OOM-9's avatar
    OOM-9
    NETGEAR Expert
    Mario is correct, the Duo v2s will not have the iSCSI support.
    There is an option between the Pro and Duo v2.... The Ultra will have the iSCSI support.
ProSupport for Business
