yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help.
1. If you are in User or Domain security mode, and you don't have "public" or "guest" access enabled for the [media] share, you will need to specify a login and password to connect from the ReadyNAS Photos desktop software. The login and password should be what you would normally use to connect to the [media] share.
2. If you are in Share security mode, and you have a password set for the [media] share, when connecting from the ReadyNAS Photos desktop software, leave the login field blank, and enter the share password.
3. If you are in User or Domain security mode, and you are an account on the ReadyNAS with the same user name but a different password as what you are using on your PC, you will need to change the password to be the same.
4. Make sure [media] share has read/write privileges over CIFS.
5. If you have installed a pre-release version of RAIDiator that had ReadyNAS Photos support (shame on you since we never really released it ;-) ), and you're having problems with the READYNASPHOTOS database, you will need to remove the ReadyNAS Photos add-on, and re-install the add-on from here.
- minervaAspirant
Eagle Eyes wrote: I have upgraded to RAIDiator 4.2.9 how do I now enable the ReadyNAS Photos and BitTorrent Download Manager?
I've looked in Services > Installed Add-ons but only find the ReadyNAS Remote v1.0.9.25 and nothing else...
You can get the ReadyNAS Photos addd on here : http://www.readynas.com/?page_id=617 - mdgm-ntgrNETGEAR Employee Retired
minerva wrote: Eagle Eyes wrote: I have upgraded to RAIDiator 4.2.9 how do I now enable the ReadyNAS Photos and BitTorrent Download Manager?
That's the Sparc link (e.g. for NV+, Duo, 1100). The link for x86 e.g. the NVX is here: http://www.readynas.com/?page_id=608. - kclarkAspirantCan not Connect ReadyNAS Photos share exit code 32
Hello,
I have the following setup:- ReadyNAS Duo
RAIDiator 4.1.6 [1.00a043]
ReadyNas Photos Service v2.2 (Service installed and enabled)
ReadyNas Photos application 1.1 for Linux (icon is shown in Notification area)
media share has full read/write access over CIFS, NFS and FTP
CIFS has 'Allow guest' enabled.
The webserver (http://localhost:1025/readynas/template/index.jsp?pageId=settings) finds my NAS box, but cannot connect to it.
I originally had my media/Pictures share as a symlink to /backup/machine_name/kev/Pictures, which I thought may have been causing the problem. So I moved this to 'Pictures2', and created a new folder 'Pictures' under media, with full permissions. Yet when I try to connect I get the same error. I have tried using with and without authentication (using my NAS local account and using the root account), but same result.
Here is the full error:Unable to connect to ReadyNAS Photos share on 192.168.0.2
share=[hostname=192.168.0.2, share=Dekoh$], exit code=[32], error=[Warning: mapping 'guest' to 'guest,sec=none' ]
Any pointers would be grateful.
Thanks,
Kevin - jeoomkensAspirantHello,
I currently own a ReadyNAS NVX for one moth now, so far I didn't run into any significant problems and I am happy the way this thing works. But now I've got a problem which I can't solve. I've read a view other posts on this topic but they didn't offer me any solution.
So what's my problem: I tried to install the add-on via System/Update/Local to my NVX but it says "invalid image" - I used to "latest" version of ReadyNAS Photo - ReadyNAS_Photos_2.2-x86.bin
I use RAIDiator 4.2.11 - and RAIDar 4.3.0
I rebooted the NVX several times, I also redownloaded the file... - Nothing works and it keeps saying "invalid image"
So maybe the image isn't compatibel with this version of RAIDiator? I don't know
Help!! Anyone?
J.
*** EDIT 28/06/2010***
I located the image in the media share of the readynas and then installed the image. That helped!
I now got a fully functioning readyNAS photos! :D - betty23AspirantHello all,
I bought the readynas duo about a month ago. Until a few days ago, my readynas photos was working just fine. Now whenever I share an album with a recipient, the email is NOT received. I can't think of anything that has changed.
I have tried sharing with gmail, yahoo, and university domains. Nothing.
I have tried unsharing and then resharing albums, rebooting and restarting the readynas, and trying to send from Mac OSX and from PC. Still the email is not received!
What can I do?
Thanks! - vwmooseAspirantBetty,
I don't know for sure but I'm guessing they are having problems with email confirmations and links etc as I've tried creating a readynasphoto login three times today with three different email addresses and haven't received any of the email confirmations.
Hope they sort it soon!
Cheers
Phil - betty23AspirantHmm..
Is anyone else having this problem? Can one of the board mods confirm? - jambalayaAspirantSame issue it's appears to be both the user sign up email and invite emails for the photos. I started having issues on Friday evening 8/13 since then...some portal appears to be down at the dekoh website.
I'm surprised there isn't a failover of some kind. - blueray1Aspirant
betty23 wrote: Hmm..
Also having this problem. Share emails are not received. - Sunday_Afterno1AspirantUser sign-up is not working for me...
