yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help.
1. If you are in User or Domain security mode, and you don't have "public" or "guest" access enabled for the [media] share, you will need to specify a login and password to connect from the ReadyNAS Photos desktop software. The login and password should be what you would normally use to connect to the [media] share.
2. If you are in Share security mode, and you have a password set for the [media] share, when connecting from the ReadyNAS Photos desktop software, leave the login field blank, and enter the share password.
3. If you are in User or Domain security mode, and you are an account on the ReadyNAS with the same user name but a different password as what you are using on your PC, you will need to change the password to be the same.
4. Make sure [media] share has read/write privileges over CIFS.
5. If you have installed a pre-release version of RAIDiator that had ReadyNAS Photos support (shame on you since we never really released it ;-) ), and you're having problems with the READYNASPHOTOS database, you will need to remove the ReadyNAS Photos add-on, and re-install the add-on from here.
- minervaAspirantHi Micheal,
Does the user you are connecting to ReadyNAS as, have read & write permissions in media share ?
Does user name or password have empty spaces or ':' or '@' ?
In both these cases, the above error message is shown. This will be rectified.
-minerva - beck2oldschoolAspirantHi minerwa,
when the check at "authentication neccesary" is not set, I get the message as written in first post.
When I set "authentication neccesary" and fill in the credentials of the NAS Admin I get the error message "A connection to ReadyNAS Photo Share is not neccessary, yet. Is the ReadyNAS Photo Service active? share=[hostname=192.168.100.33, share=Dekoh$, username=admin], exit code=[2], error=[Systemerror 2221. ]"
The Service is started ;-)
On the media share everyone has full access. All Subfolders has inherit the rights of the "media" share.
Michael - k_3poAspirantHi Micheal,
For the browser on your desktop to connect to be able to connect to internet, do you need to enter set any proxy server?
/k-3po - beck2oldschoolAspirantNo
- erlangerboysAspirantHi, Just recently installed a readynas duo. Have enabled the photo service and downloaded the desktop software. It get around 30% of performing the install and then exits with an error suggesting delete a folder and try again. The error being generated is identical to the posting on this thread from NOTSURE of 11 Feb 2009. I have made sure that all versions of the software and firmware are as advised on this site.
Cheers
Andy - minervaAspirantCan you send me in a private message the install.log thats in C:\Dekoh (win) ~/Dekoh (Mac) folder ?
- mvengAspirantThough I used ReadyNAS Photos before, I have been unable to use recently.
When I log in after I input my user name and password (which are the same for the Media share), I get authenticated and then I get the following (with minor edits to protect privacy):
"Unable to connect to media/Pictures share on [correct address for the ReadyNAS...]"
When expanding the error message I get:
share=[hostname=[ReadyNAS address], share=media, folder=Pictures, username=[correct user name]], exit code=[17], error=[mount_smbfs: mount error: /Users/.../Dekoh/mnt/[username]55965979/media: File exists ]"
I tried to login as a different user and received the exact same message (with the different user name obviously).
I am using a macbook with ReadyNAS 600 with the RAIDiator 4.1.6 [1.00a147] and I already uninstalled and reinstalled the ReadyNAS Photos application and stopped and restarted the service on the NAS.
Any suggestions as to next steps? - minervaAspirantYou can try the following.
Stop ReadyNAS Photos application, and try deleting the ~\Dekoh\mnt folder by yourself. Restart ReadyNAS Photos and retry connecting to ReadyNAS. - Eagle_EyesAspirantI've just purchased the Netgear ReadyNAS NVX RNDX4250 which is running the ReadyNAS NVX Business Edition and I can't seem to find any Add-ons.
I have upgraded to RAIDiator 4.2.9 how do I now enable the ReadyNAS Photos and BitTorrent Download Manager?
I've looked in Services > Installed Add-ons but only find the ReadyNAS Remote v1.0.9.25 and nothing else...
What do I do now? - MaxNASAspirantHello,
I've had my readynas for a bit now, and just recently decided to try and setup the readynas photos. I get it all installed and created a login ID and password. This allows me to login and see my readynas box but, when i click it, another window comes up and i enter a username/password (same as i use to login through finder). And gives me a message at the bottom stating 'Invalid Credentials', I've tried every password possible that i setup on the unit and non work.
I do have SMB / CIFS enabled, along with all users have read/write abilities within the 'media' share. I read what the support agent stated at the start of this forum but do not understand it fully, both passwords from the admin to mine are exact the same, but still fails. I am setup with the 'user' security mode.
Am I doing something wrong?
Nick
