shedz
May 07, 2014Aspirant
Speeding up upload speeds from ReadyNAS 312
Hi all forums users, legends and techies I own a ReadyNAS 312 with 2 x 3TB HDD and a netgear N150 dgn1000 router. I am experiencing really slow upload speeds when I access my server externally via ...
May 12, 2014Guru - Experienced User
Ok. Since you have dsl, I think you are running PPPoE on your ISP connection. That usually lowers to MTU to 1480, which is what you are seeing.
You can try to limit the 312's MTU to 1480. That won't hurt performance on your local lan (at least not enough to matter), but could reduce fragmentation over the internet.
