noilly
Nov 06, 2011Aspirant
Transmission constantly turns inactive
Hi,
I am having an issue where the Tranismission service seems to constantly become inactive. I.e. The active "LED" is grey (not green.)
I am running Transmission 2.42 and RAIDiator 4.1.8.
I have to manually start Transmission and the time between it becoming active and inactive is generally only a few minutes. The Tranmission web interface also shows the error "Could not connect to the server. You may need to reload the page to reconnect."
This has happened with the previous version of RAIDiator and previous versions of Transmission, so I am not sure what the problem is. Any help would be greatly appreciated.
Thanks!
Thanks!
- ReadyNDSIAspirantsame problems here, it stops, annoying.. "NETGEAR, Connect with nothing" at this rate.
- spiritxAspirantHello,
To may be help Super Poussin to solve the problem i've logs :
Firstly i've this one
Nov 21 20:27:23 readynasduo transmission-daemon[20094]: TorrentName Piece 471, which was just downloaded, failed its checksum test (peer-mgr.c:1791)
And after few minutes :
Nov 21 20:40:45 readynasduo kernel: oom-killer: gfp_mask=0x200d2, order=0
Nov 21 20:40:45 readynasduo kernel: [8006698c : read_swap_cache_async+0xb8/0xd8 ] [8005e724 : do_swap_page+0x3d4/0x48c ] [8005f084 : __handle_mm_fault+0x154/0x4a4 ] [803410f4 : 0x803410f4 ] [80340110 : 0x80340110 ] [00001009 : 0x1009 ]
Nov 21 20:40:45 readynasduo kernel: Mem-info:
Nov 21 20:40:45 readynasduo kernel: DMA per-cpu:
Nov 21 20:40:45 readynasduo kernel: cpu 0 hot: high 0, batch 1 used:0
Nov 21 20:40:45 readynasduo kernel: cpu 0 cold: high 0, batch 1 used:0
Nov 21 20:40:45 readynasduo kernel: DMA32 per-cpu: empty
Nov 21 20:40:45 readynasduo kernel: Normal per-cpu:
Nov 21 20:40:45 readynasduo kernel: cpu 0 hot: high 18, batch 3 used:1
Nov 21 20:40:45 readynasduo kernel: cpu 0 cold: high 6, batch 1 used:5
Nov 21 20:40:45 readynasduo kernel: HighMem per-cpu: empty
Nov 21 20:40:45 readynasduo kernel: Free pages: 3920kB (0kB HighMem)
Nov 21 20:40:45 readynasduo kernel: Active:13593 inactive:317 dirty:0 writeback:0 unstable:0 free:245 slab:636 mapped:13353 pagetables:0
Nov 21 20:40:46 readynasduo kernel: DMA free:1168kB min:112kB low:128kB high:160kB active:0kB inactive:0kB present:16384kB pages_scanned:0 all_unreclaimable? yes
Nov 21 20:40:46 readynasduo kernel: lowmem_reserve[]: 0 0 60 60
Nov 21 20:40:46 readynasduo kernel: DMA32 free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pages_scanned:0 all_unreclaimable? no
Nov 21 20:40:46 readynasduo kernel: Normal free:2752kB min:1840kB low:2288kB high:2752kB active:217488kB inactive:5072kB present:245760kB pages_scanned:13303 all_unreclaimable? no
Nov 21 20:40:46 readynasduo kernel: lowmem_reserve[]: 0 0 0 0
Nov 21 20:40:46 readynasduo kernel: HighMem free:0kB min:512kB low:512kB high:512kB active:0kB inactive:0kB present:0kB pages_scanned:0 all_unreclaimable? no
Nov 21 20:40:46 readynasduo kernel: DMA: 1*16kB 0*32kB 0*64kB 1*128kB 0*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB = 1168kB
Nov 21 20:40:46 readynasduo kernel: DMA32: empty
Nov 21 20:40:46 readynasduo kernel: Normal: 58*16kB 7*32kB 5*64kB 2*128kB 0*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB = 2752kB
Nov 21 20:40:46 readynasduo kernel: HighMem: empty
Nov 21 20:40:46 readynasduo kernel: Swap cache: add 431022, delete 428371, find 59611/128573, race 2+0
Nov 21 20:40:46 readynasduo kernel: Free swap = 40272kB
Nov 21 20:40:46 readynasduo kernel: Total swap = 255968kB
Nov 21 20:40:46 readynasduo kernel: Free swap: 40272kB
Nov 21 20:40:46 readynasduo kernel: 14141 pages of RAM
Nov 21 20:40:46 readynasduo kernel: 245 free pages
Nov 21 20:40:46 readynasduo kernel: Out of Memory: Kill process 20094 (transmission-da) score 43412 and children.
Nov 21 20:40:46 readynasduo kernel: Out of memory: Killed process 20094 (transmission-da).
Nov 21 20:40:46 readynasduo kernel: Out of memory: Killed process 20095 (transmission-da).
Nov 21 20:40:46 readynasduo kernel: Out of memory: Killed process 20096 (transmission-da).
Nov 21 20:40:46 readynasduo kernel: Out of memory: Killed process 20097 (transmission-da).
Kind regards - Dickie1AspirantHaving to use the pre-installed BitTorrent add-on whilst this is sorted :(
- mealerzAspirantOK so I thought it was the password error but it's not. Thinking of just buying more ram for my box.
God this is seriously annoying me now! :-( - WizballAspirantNow done a memory upgrade and it seems to be stable again.
Wizball wrote: BikeHelmet wrote: Wizball wrote: So with the info above does anyone know of any problems with down grading to the earlier firmware?
Problems? I think downgrading requires a factory reset, so you need a backup of all your data? That's the main "problem".
OK down graded my ready nas NV+ it does not have a memory upgrade and transmission is still stopping. I will have to work out what has changed as it never use to. - mealerzAspirant
Wizball wrote: Now done a memory upgrade and it seems to be stable again.
What do you have? NV or Duo?
I have a Duo and I think I'll just buy 1gb of ram for it to try. Otherwise I'm binning this and buying a qnap box. Seriously sucks, I wish I never upgraded to the latest firmware.
I can only think of resetting the box by pulling out a drive, resetting it to factory defaults (would that get me back to factory firmware also? ) then putting my other drive in a caddy and transferring all the data back to the nas again, which would take so long.
This has got to be permissions problem surely. Something is hanging and not timing out?
Does anyone have an easier way to go back a firmware upgrade? - WizballAspirantI have an nv.
Just download the old firmware and used that to update. - Russell_CoightAspirantI'm getting the same problem.
Transmisison 2.42, RAIDiator 4.1.8.
top from SSH shows:
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
21422 nobody 33 18 236m 142m 3952 R 6.9 64.6 8:35.64 transmission-da
With only 1 torrent going. I've tried a fresh install of Transmission with no luck.
Would a RAM upgrade help? Is it possible to restart transmission-daemon via SSH?
thanks - noillyAspirantHi All,
I have solved my problem!
After months of my Transmission turning off every few minutes, it has now been running for over three hours straight downloading multiple torrents.
Steps I took to solve issue:
1. Install latest version of Transmission (2.42)
2. Stop the Transmission service
3. Navigate to and open the settings.json file (..\addons-config\Transmission\transmission-daemon\). Notice that on the fresh install of v2.42, the settings.json file has a valuecache-size-mb = 200
4. Change cache-size-mb tocache-size-mb = 2
5. Save the file
6. Restart the Transmission service
Happy torrenting!
I would love to know if this works for others, so please post if the above steps solved your issues too! - BikeHelmetAspirant
noilly wrote: 3. Navigate to and open the settings.json file (..\addons-config\Transmission\transmission-daemon\). Notice that on the fresh install of v2.42, the settings.json file has a value cache-size-mb = 200
Is the default value in 2.42 so high?
I found any value above ~20 caused stability issues in past versions. I think I had mine set to 8MB to cut out a bit of I/O without gobbling all the RAM.
