KgOlve's avatar
KgOlve
Transmission installation problem
Hi,
I've got a Netgear Ultra 2 NAS, and am trying to install Transmission BitTorrent client. However earlier on when i tried it had a "Failed installation" for some reason. Nothing appeared in the "Installed Add-ons" tab. So i tried to install it again, then i get the error message "Installation of this add-on conflicts with an existing service. Aborting installation." after uploading the .bin file and clicking "Install". I tried with both the latest stable release, and the latest beta release, both gives the same error. So i tried to restore the NAS to factory defaults, but it did not fix the error.
Please help.
Regards, KgOlve.
Also, sorry if this was the wrong section to post this, did not see a "Bug Reports" section.
  • I see, so there was another way to fix it :roll:
    I tried this suggestion now, and will see how it fares. The torrent hasn't gotten the error yet atleast, hopefully it won't get it at all.
    Thank you for your help :)
  • sorry if this is a noob question, but how do i ssh into the nas? i have installed openssh, what is the command i need to enter in terminal? "root @ 192.168.0.21" ??
    thanks
  • The command used to ssh into the NAS from a terminal would be
    ssh root@ip.address.of.nas
    -Stefan
    -Stefan
    Thanks Stefan,
    any idea on this?
    Bens-MacBook-Air:~ Ben$ ssh root@192.168.0.21
    @ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
    IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
    Someone could be eavesdropping on you right now (man-in-the-middle attack)!
    It is also possible that the RSA host key has just been changed.
    The fingerprint for the RSA key sent by the remote host is
    4f:7f:75:da:7e:8d:6d:d9:f9:57:a8:b9:f9:b5:ca:94.
    Please contact your system administrator.
    Add correct host key in /Users/Ben/.ssh/known_hosts to get rid of this message.
    Offending key in /Users/Ben/.ssh/known_hosts:2
    RSA host key for 192.168.0.21 has changed and you have requested strict checking.
    Host key verification failed.
    I managed to get around it using Putty on windows and run the suggested commands, but i still can't get transmission to run, not even older versions? please can you take a look at this thread and see if you have any suggestions? http://www.readynas.com/forum/viewtopic.php?f=36&t=63327
    Thanks again for the help mate
  • The output above means that either you have re-installed /factory-reset your ReadyNAS after having been able to SSH into it earlier or that your ReadyNAS uses an IP address that had been assigned to another piece of equipment before. Either way, the RSA host key that your Mac previously associated with the host 192.168.0.21 is different from what your ReadyNAS is presenting and that's what is causing the message. The reason PuTTY doesn't complain is that most likely it was the first time you used it to connect.
    As for your installation problem: Sorry, I'm neither the author of Transmission on the x86 ReadyNAS platform nor do I have it installed/use it, so I can't really provide help there.
    -Stefan
  • Thanks for your help, thinking about it, i assigned my old NAS the same IP so it must have been that.
    I'll try and be patient and wait for help on the other thread.
    Thanks again!
ProSupport for Business
