Groodles
Dec 06, 2017Aspirant
2100V2 USB Ports not mounting
All USB ports (1 front and 2 rear) fail to mount USB devices (HDD or Memory Sticks) /var/log/messages shows the following, but nothing appears in Frontview and I cant select USB ports for backup ...
Groodles
Dec 07, 2017Aspirant
So I've plugged either a HDD or USB Flash into all of the ports. dmesg logged the following:
[80022.310965] usb-storage 2-3:1.0: USB Mass Storage device detected [80022.312340] scsi host8: usb-storage 2-3:1.0 [80028.153385] scsi 8:0:0:0: Direct-Access BUFFALO External HDD PQ: 0 ANSI: 2 CCS [80028.154623] sd 8:0:0:0: Attached scsi generic sg4 type 0 [80028.157875] sd 8:0:0:0: [sde] 1465149168 512-byte logical blocks: (750 GB/699 GiB) [80028.158784] sd 8:0:0:0: [sde] Write Protect is off [80028.158798] sd 8:0:0:0: [sde] Mode Sense: 34 00 00 00 [80028.159744] sd 8:0:0:0: [sde] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA [80028.255549] sde: sde1 [80028.258831] sd 8:0:0:0: [sde] Attached SCSI disk [80055.029039] usb 2-2: new high-speed USB device number 5 using ehci-pci [80055.144949] usb-storage 2-2:1.0: USB Mass Storage device detected [80055.146465] usb-storage 2-2:1.0: Quirks match for vid 152d pid 2329: 8020 [80055.147158] scsi host9: usb-storage 2-2:1.0 [80056.149974] scsi 9:0:0:0: Direct-Access ST1000LM 024 HN-M101MBB PQ: 0 ANSI: 2 CCS [80056.151271] sd 9:0:0:0: Attached scsi generic sg5 type 0 [80056.151861] sd 9:0:0:0: [sdf] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB) [80056.154722] sd 9:0:0:0: [sdf] Write Protect is off [80056.154736] sd 9:0:0:0: [sdf] Mode Sense: 34 00 00 00 [80056.155862] sd 9:0:0:0: [sdf] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA [80056.804700] sdf: sdf1 [80056.808434] sd 9:0:0:0: [sdf] Attached SCSI disk [80063.718037] usb 2-4: new high-speed USB device number 6 using ehci-pci [80063.841078] usb-storage 2-4:1.0: USB Mass Storage device detected [80063.841341] scsi host10: usb-storage 2-4:1.0 [80064.845253] scsi 10:0:0:0: Direct-Access Generic Flash Disk 8.07 PQ: 0 ANSI: 4 [80064.846370] sd 10:0:0:0: Attached scsi generic sg6 type 0 [80064.849400] sd 10:0:0:0: [sdg] 7925760 512-byte logical blocks: (4.06 GB/3.78 GiB) [80064.851073] sd 10:0:0:0: [sdg] Write Protect is off [80064.851087] sd 10:0:0:0: [sdg] Mode Sense: 23 00 00 00 [80064.852271] sd 10:0:0:0: [sdg] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA [80064.862481] sdg: sdg1 [80064.866931] sd 10:0:0:0: [sdg] Attached SCSI removable disk
So I can see that each device is found, names and the partitions identified.
Groodles
Output of: ls -l /sys/block
lrwxrwxrwx 1 root root 0 Dec 7 12:32 loop0 -> ../devices/virtual/block/loop0 lrwxrwxrwx 1 root root 0 Dec 7 12:32 loop1 -> ../devices/virtual/block/loop1 lrwxrwxrwx 1 root root 0 Dec 7 12:32 loop2 -> ../devices/virtual/block/loop2 lrwxrwxrwx 1 root root 0 Dec 7 12:32 loop3 -> ../devices/virtual/block/loop3 lrwxrwxrwx 1 root root 0 Dec 7 12:32 loop4 -> ../devices/virtual/block/loop4 lrwxrwxrwx 1 root root 0 Dec 7 12:32 loop5 -> ../devices/virtual/block/loop5 lrwxrwxrwx 1 root root 0 Dec 7 12:32 loop6 -> ../devices/virtual/block/loop6 lrwxrwxrwx 1 root root 0 Dec 7 12:32 loop7 -> ../devices/virtual/block/loop7 lrwxrwxrwx 1 root root 0 Dec 7 12:32 md0 -> ../devices/virtual/block/md0 lrwxrwxrwx 1 root root 0 Dec 7 12:32 md1 -> ../devices/virtual/block/md1 lrwxrwxrwx 1 root root 0 Dec 7 12:32 md127 -> ../devices/virtual/block/md127 lrwxrwxrwx 1 root root 0 Dec 7 12:32 sda -> ../devices/pci0000:00/0000:00:1f.2/ata1/host0/target0:0:0/0:0:0:0/block/sda lrwxrwxrwx 1 root root 0 Dec 7 12:32 sdb -> ../devices/pci0000:00/0000:00:1f.2/ata2/host1/target1:0:0/1:0:0:0/block/sdb lrwxrwxrwx 1 root root 0 Dec 7 12:32 sdc -> ../devices/pci0000:00/0000:00:1f.2/ata5/host4/target4:0:0/4:0:0:0/block/sdc lrwxrwxrwx 1 root root 0 Dec 7 12:32 sdd -> ../devices/pci0000:00/0000:00:1f.2/ata6/host5/target5:0:0/5:0:0:0/block/sdd lrwxrwxrwx 1 root root 0 Dec 7 12:32 sdf -> ../devices/pci0000:00/0000:00:1d.7/usb2/2-2/2-2:1.0/host7/target7:0:0/7:0:0:0/block/sdf lrwxrwxrwx 1 root root 0 Dec 7 12:32 sdg -> ../devices/pci0000:00/0000:00:1d.7/usb2/2-3/2-3:1.0/host8/target8:0:0/8:0:0:0/block/sdg lrwxrwxrwx 1 root root 0 Dec 7 12:32 sdh -> ../devices/pci0000:00/0000:00:1d.7/usb2/2-4/2-4:1.0/host9/target9:0:0/9:0:0:0/block/sdh
