NASCHARGE
Dec 12, 2014Aspirant
6.2 update connection lost
Hi, I have a pro 6 that I have upgraded from 4.2.27 to 6.2 After the upgrade I was able to access the gui but after a reboot I can no longer access. Just receive connection lost. I have tried to ...
RX
Dec 12, 2014Luminary
Firmware v6.2.0 is just meant to be used with ReadyNAS OS 6 models. ReadyNAS Pro 6 is an Intel-based ReadyNAS OS 4 model.
I do not have a ReadyNAS Pro 6, however, if its possible to revert the firmware back to v4.2.27...kindly try to update the firmware to v6.1.9 first then perform a factory reset then update it to v6.2.0.
