givememynamebak
Feb 01, 2019Luminary
6.9.5 Check For Updates - Fails
After upgrading to 6.9.5 no matter if I am using Settings --> Check For Updates or Overview --> Check for updates. It always results in the following error since updating to 6.9.5.
Anyone h...
Feb 01, 2019Guru - Experienced User
I am seeing that too. It also failed the same way on a 6.9.4 NAS, so I think the Netgear update server is likely down.
givememynamebak
StephenB Thank you for verifying. Glad it's not only me :-) Much appreciated!
- Jul 31, 2022Retired_Member
