emd1
Feb 12, 2013Aspirant
A disk failure will render this volume dead
Hello, I have a ReadyNas NV+ [RND4450] that was complaining of "Reallocated sector counts" on disk 4. I have 4 Seagate ST31500341AS [1397 GB] installed and always kept a spare drive on the shelf in ...
ReadySECURE
Feb 12, 2013Apprentice
You had 1 disk fail, but what is the status of the other disks? Are they bad, too? If they are also bad, you can have problems resyncing your volume. As soon as it starts to sync and hits a bad part of the disk, you could expect the drive to stop resyncing and leave it non-redundant as it only partially restriped the data onto the disk.
Could you post some logs online that we may look at? All of the logs preferred.
