emd1
Feb 12, 2013Aspirant
A disk failure will render this volume dead
Hello, I have a ReadyNas NV+ [RND4450] that was complaining of "Reallocated sector counts" on disk 4. I have 4 Seagate ST31500341AS [1397 GB] installed and always kept a spare drive on the shelf in ...
emd1
Feb 13, 2013Aspirant
here is disk_smart.log I'm hoping that is what you wanted.
***** smartctl output for hdc *****
smartctl 5.42 2011-10-20 r3458 [padre-linux-2.6.17.14ReadyNAS] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family: Seagate Barracuda 7200.11
Device Model: ST31500341AS
Serial Number: 9VS1ADZN
LU WWN Device Id: 5 000c50 0110ec61b
Firmware Version: CC1H
User Capacity: 1,500,301,910,016 bytes [1.50 TB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Tue Feb 12 08:53:29 2013 EST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 617) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x103f) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 112 099 006 Pre-fail Always - 48074302
3 Spin_Up_Time 0x0003 100 100 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 15
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 7
7 Seek_Error_Rate 0x000f 081 060 030 Pre-fail Always - 163401398
9 Power_On_Hours 0x0032 063 063 000 Old_age Always - 33132
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 15
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 1 (1, 1)
189 High_Fly_Writes 0x003a 001 001 000 Old_age Always - 105
190 Airflow_Temperature_Cel 0x0022 069 053 045 Old_age Always - 31 (Min/Max 29/34)
194 Temperature_Celsius 0x0022 031 047 000 Old_age Always - 31 (0 16 0 0 0)
195 Hardware_ECC_Recovered 0x001a 033 015 000 Old_age Always - 48074302
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 265295834939756
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 2914827473
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 240728476
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
***** smartctl output for hde *****
Serial Number: 9VS1D6M3
LU WWN Device Id: 5 000c50 0111ea1b1
ATA Version is: 8
been run.
data collection: ( 609) seconds.
command.
power-saving mode.
1 Raw_Read_Error_Rate 0x000f 119 099 006 Pre-fail Always - 233536637
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 14
5 Reallocated_Sector_Ct 0x0033 098 098 036 Pre-fail Always - 118
7 Seek_Error_Rate 0x000f 081 060 030 Pre-fail Always - 159964006
9 Power_On_Hours 0x0032 063 063 000 Old_age Always - 33058
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 14
189 High_Fly_Writes 0x003a 001 001 000 Old_age Always - 267
190 Airflow_Temperature_Cel 0x0022 064 049 045 Old_age Always - 36 (Min/Max 34/39)
194 Temperature_Celsius 0x0022 036 051 000 Old_age Always - 36 (0 16 0 0 0)
195 Hardware_ECC_Recovered 0x001a 037 019 000 Old_age Always - 233536637
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 138701673890081
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1472814106
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 3139649318
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
***** smartctl output for hdg *****
Serial Number: 9VS1DPGM
LU WWN Device Id: 5 000c50 0111dd4a8
ATA Version is: 8
Local Time is: Tue Feb 12 08:53:31 2013 EST
been run.
command.
power-saving mode.
1 Raw_Read_Error_Rate 0x000f 119 099 006 Pre-fail Always - 215951700
5 Reallocated_Sector_Ct 0x0033 099 099 036 Pre-fail Always - 44
7 Seek_Error_Rate 0x000f 081 060 030 Pre-fail Always - 134505339
9 Power_On_Hours 0x0032 063 063 000 Old_age Always - 33063
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 001 001 000 Old_age Always - 231
190 Airflow_Temperature_Cel 0x0022 064 051 045 Old_age Always - 36 (Min/Max 34/39)
194 Temperature_Celsius 0x0022 036 049 000 Old_age Always - 36 (0 16 0 0 0)
195 Hardware_ECC_Recovered 0x001a 036 021 000 Old_age Always - 215951700
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 133217000653095
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1216653438
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 2999430668
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
***** smartctl output for hdi *****
Serial Number: 9VS2W5FA
LU WWN Device Id: 5 000c50 019abfd7a
ATA Version is: 8
Local Time is: Tue Feb 12 08:53:32 2013 EST
been run.
command.
power-saving mode.
1 Raw_Read_Error_Rate 0x000f 100 100 006 Pre-fail Always - 11443
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 3
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 100 253 030 Pre-fail Always - 488260
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 144
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 3
189 High_Fly_Writes 0x003a 099 099 000 Old_age Always - 1
190 Airflow_Temperature_Cel 0x0022 068 066 045 Old_age Always - 32 (Min/Max 22/34)
194 Temperature_Celsius 0x0022 032 040 000 Old_age Always - 32 (0 22 0 0 0)
195 Hardware_ECC_Recovered 0x001a 100 100 000 Old_age Always - 11443
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 27891517620368
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 571466798
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 248
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
