jh75
Nov 08, 2016Aspirant
Adding 4TB - total storage volume not increased
Hi,
We have a Readynas nv+ v2 used for backing up to. It has 4x2TB hdd’s. The NAS has run out of space and I am in process of adding 2 new 4TB drives.
I am adding one drive at the time and have ...
- Nov 08, 2016
jh75 wrote:
I am adding one drive at the time and have only added 1 drives so far. After adding 1x 4TB drive the storage ‘size’ has not increased – it seems that only 2TB of the new drive is used.
This is normal. The system can't use the full drive space without sacrificing RAID redundancy.
When you add the second disk there will be a second resync and the volume will expand by 2 TB. You likely will be prompted to reboot the NAS half-way through that resync
Nov 11, 2016Guru - Experienced User
JBDragon1 wrote:
You can see this looking at the HDD storage space Calculator.
http://rdconfigurator.netgear.com/raid/index.html
Alternatively, for the default XRAID you can sum the disks and subtract the largest. That will give you the results in TB (see below).
JBDragon1 wrote:
3.64 is the amount of storage space on a 4TB HDD.
To explain this a bit more fully - there are two units of measure here. The disk drive is 4 TB. 1 TB = 1000*1000*1000*1000 bytes. 3.64 is what the NAS volume will show, because it is using TiB, not TB. 1 TiB = 1024*1024*1024*1024 bytes - about 10% bigger than 1 TB. Unfortunately the NAS (like Windows) labels the size as TB or GB - even though it is really TiB or GiB.
JBDragon1 wrote:
Losing storage space for Redundancy is worth it. It's still no BACKUP!!! ... Don't count on a NAS to save your Data!!!
Totally agree here. RAID is simply not enough to keep your data safe - for all the reasons you mention. Unfortunately a lot of people discover this the hard way.
JBDragon1
Nov 12, 2016Virtuoso
Should we blame Microsoft or the HDD makers for Advertising sizes, or showing sizes that that really confuse everyone. Isn't it the whole RAM thing being 1024, while HDD are 1000, and Windows just treats them both the same at 1024? So while RAM shows correctly, HDD space shows less, because all them 24 bytes extra add up. I'm not sure why they didn't just both just be the same? Either Ram or Storage, but it's been confusing people for a very long time.
- StephenBNov 12, 2016Guru - Experienced User
JBDragon1 wrote:
Should we blame Microsoft or the HDD makers for Advertising sizes ... Either Ram or Storage, but it's been confusing people for a very long time.
It's been this way so long, I'm not sure who started it. I recall (many years ago) that 1024 multiples were used in early PCs to avoid the divide (using a right shift instead). Though that is anecdotal, and might well be wrong. Though of course 1024 is the logical unit for RAM.
- SandsharkNov 12, 2016Sensei
StephenB wrote:It's been this way so long, I'm not sure who started it. I recall (many years ago) that 1024 multiples were used in early PCs to avoid the divide (using a right shift instead). Though that is anecdotal, and might well be wrong. Though of course 1024 is the logical unit for RAM.
RAM uses multiples of 1024 because there are physical address lines, so the total number of locations must be a power of two (a round number in binary) since each line has two possible states (0 and 1). So it only made sense that a Kilo, Mega, Giga, etc. would be a multiple of 1024 (an even power of 2) instead of 1000. This was established before hard drives even existed by general usage, not by actual standard. The shift instead of divide by two has similar roots (two states for each location vs, two states for each address line), but they are not hard linked.
Hard drives have no similar physical restriction. I remember 17 sectors per track being common as 5.25" hard drives became mainstream, but that varied some between manufacturers. In the very early years, some manufacturers used multiples of 1024 for drives as well, but their drives "looked smaller" than the competition that used multiples of 1000, so multiples of 1000 became the norm (as well as folllowing the IEC standard, where multiples of 1024 did not). Rounding drive size up instead of using fractional sizes also became the norm. These and the "raw vs, formatted" capacity all add to the confusion of just how much a drive will hold. The bottom line is the drive manufaturers all want their drives to advertise as being as large as they can get away with.
In 1999, the IEC decided enough was enough and invented (or at least standardized) the KiB, GiB, TiB, etc. for binary multiples. Computers were now mainstream, and the old "industry standards" were confusing to the general populous, especially since that extra 24 doesn't actually "add up", it multiplies. The difference was really staring to show with TB=1000x1000x1000x1000 vs. TiB=1024x1024x1024x1024. But except to explain the difference between the size of drives and RAM, the "KiB", "GiB", "TiB", etc. have yet to become commonly used in the electronics industry. 1024 bytes of RAM is still a "K" not a "Ki" pretty much everywhere I look. Microsoft is just following the crowd (or stagnating with it, I suppose), and the confusion persists. Blame old guys (and gals) like me and Bill Gates (though he's out of the game now) for this.
Here is a good reference: Prefixes for binary multiples
- StephenBNov 14, 2016Guru - Experienced User
I believe OSX uses 1000 multiples, so confusion continues to abound.
My recollection on the shift went back to the CP/M operating system, which of course was back when dinosaur computers roamed the earth. https://en.wikipedia.org/wiki/CP/M
